Relief Valve
   / Relief Valve #1
rock2610D
Cheyenne WY
2610D
Could someone tell me where this is located? I have be advised that I could have a malfunctioning one.
I have a clicking/thumping sound when raising loader and curling bucket. No clicking sound when lowering bucket or uncurling bucket. Also happens when raising 3pt.
Rock
   / Relief Valve #2
If I'm not mistaken,( & that's possible) it's inside the hyd pump itself
   / Relief Valve
Looked at my pump info in my manual and there is nothing to suggest a relief valve on or in pump.
I did find some other relief valves but am not sure they are what I am looking for.
1st is on gadget that has the stop valve on it under seat. Its called a main system relief valve.
2nd is whats called a rock shaft relief valve and its also on the gadget under the seat.
Could one of these cause the noise I hear??
   / Relief Valve #4
There is one inside your loader valve & one inside the 3pt valve. Send me an email & I'll send you some pictures of where it is at.
The loader & 3pt hitch use a separate relief valve. I doubt the clicking in both the loader & 3pt are because of that. It sounds to me like it could be something slipping in your pump drive system when under a load. We have seen several times where a key or the coupler get stripped and start to slip when the hydraulic system gets pressured up and the pump gets hard to turn. It make sort of a clicking sound. Can you tell where the sound is coming from?
Just a thought.
Aaron
Parts@HoyeTractor.com
(940)592-0181
   / Relief Valve
Sound is definately coming from the right hand front part of the engine. Where the pump is.
Sound is still there even when the loader is disconnected. Its a Allied loader and loader controll has a bypass system so it can be disconnected and not dead head pump.
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A53473)
2017 Ford F550...
Killbros 260 Seed Conveyor (A53473)
Killbros 260 Seed...
2017 Mack CHU613 Day Cab Truck Tractor (A53117)
2017 Mack CHU613...
2020 Bell B30E Off Road Dump Truck (A53117)
2020 Bell B30E Off...
