Reliable pull behind mowers?
   / Reliable pull behind mowers? #21
I had a commercial grade Alamo flail mower with the Honda red engine. An excellent machine. But towing with my ATV was not good. ATV's aren't geared for slow, steady towing under load and every hill or turn was met by a bog-down followed by a leap forward. And sitting on an ATV isn't near as comfortable as on a tractor. No experience with a side-by-side so that might go better. I'd look at a large riding mower or the Ventrac thing.
   / Reliable pull behind mowers? #22
Do we have any reviews of this PK-AT145E Flail Mower yet??? If you seen or used one, please tell us about it.
Noticed this after mentioning it above but . . .
This is a case of "Can't blame the horse for being a cow."
I had an Alamo much like the one in your picture and it was a very high quality machine. Commercial model with Honda red engine ran about $2,400. Aside from the shortfalls of using an ATV to pull it [covered above] it just didn't fit my application. I believe they are made for mowing public places such as parks and ball fields -- they throw everything down, not out. So they cut pretty short and have relatively small wheels. I found that the front lip would catch on a chunk of high grass or small brush in a field and it would flip over forward. I added a brace and it still did it. Then I put some large go cart wheels and tires on it and it would still find something to snag on and flip over.
When doing so, it would stay running so as you went back to disengage it there were 80-some knives whirling at blinding speed -- easy enough to avoid but still not a good thing. Twice during the flip it spilled gas on the muffler which caught fire and ignited the field. A small spot but again not a good thing. Can't blame the machine, it just wasn't meant for fields and trails.
   / Reliable pull behind mowers? #23
Slopes and ATVs pulling mowers just doesn't sound very safe to me.
Perhaps a used Power-Trac 425?
Or: I put a steel cutting disk with three cutting blades on my Stihl and it cuts like a demon. Just don't cut near windows, or near anything else that you care if it gets nicked.
All the best,
Peter
   / Reliable pull behind mowers? #24
just saw this pic
   / Reliable pull behind mowers? #26
Yesterday was my first day using the Titan AT100 flail mower behind my 2003 Bombardier Quest 500. Other than my ATV being 2wd and spinning tires on some of the steeper slopes, I think it went great! I drove it up and down some pretty steep sections of my property, through some fields, got stuck and had to reverse a few times (no trickier than any trailer reversing maneuvers, aside from lack of traction a few times). I was able to drive through 5ft tall brush no problem and the mower ate it up. For some blackberry thickets, I just went a little slower and made two passes. A few places I was even able to reverse the mower into the brush and it worked real nice.
I am using the "max coupler" articulating offroad hitch, so I wouldn't have any trouble with it binding on tough terrain.
   / Reliable pull behind mowers? #27
View attachment 703209View attachment 703207
Thanks for posting. Does that machine have a clutch??
   / Reliable pull behind mowers? #28
I have a Swisher T14560A tow behind. Not underpowered but build quality sucks. Leaves 2 rows of uncut grass because the blades have gaps in between (Gator blades have helped but have to mow twice for a clean cut). Can't keep the belts on. I'm on my 2nd rebuild of all the pulleys. I would never buy a Swisher product again. I'm looking at a Kunz when I finally decide to stop dropping $$$ into the money pit Swisher. FYI I have only used factory parts and belts. It performed horribly under warranty as well, taken in several times. Bought at a TSC.
   / Reliable pull behind mowers? #29
My neighbor has A DR pull behind mower that he pulls with his ATV. It, unfortunately, is a real piece of junk. Twice I have rewelded the unit's main frame that broke in two, and it has had numerous other problems in the three years he has had it. (electrical problems, fuel leaks, etc). Don't know if there are good ones, but the DR certainly isn't one.
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
Hyster H155XL Forklift (A48837)
Hyster H155XL...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
UNUSED FUTURE SKID STEER QUICK ATTACH LAND LEVELER (A51244)
UNUSED FUTURE SKID...
2017 JCB 3TS-8T TELEKSKID SKID STEER (A51242)
2017 JCB 3TS-8T...
