Relay Switches 4720i
   / Relay Switches 4720i #1
Toby873
myakka city, Florida
Branson 4720i
Hello, I have a 4720i that I thought had bad battery; nope. Bad ignition switch; nope. Bad starter; nope. Bad wires; nope. Bad relays; yup. Problem is all the manuals say I have four of the same relays, I have three that are red and one that is blue, did I just miss one? either way I need to replace two of the red ones; Who is the best source for relay switches for a 2004 4720i in SW Florida? Thanks for help in advance.
   / Relay Switches 4720i #2
Relay's, if the little plug in cube type, are most likely a standard to the automotive industry.
I's take along the 2 suspects and have them matched at any auto parts store.
Need some more insight on this. PILOON; thanks for suggestions but unable to match at auto parts store; or anywhere on internet. Branson parts are apparently like chicken teeth.....impossible to find. I would appreciate any help from a dealer/mechanic that can definitively tell me that these four relays are the same because the blue one ends with a 'A3' while the three red ones end with 'A4'.
   / Relay Switches 4720i #4
the red relays are normally open and the blue is normally closed contacts
   / Relay Switches 4720i #5
Try Mouser Electronics. They have a huge supply of everything electronic.
   / Relay Switches 4720i #6
give Valenti tractor a call in Troy New Hampshire--had electric stuff for my olde girl
   / Relay Switches 4720i #7
It turns out that I need the blue relay for my 3820i. I'll bet it's the same switch as yours. Did you find where to buy one? My local dealer has had one on order for weeks. Nothing.
   / Relay Switches 4720i #8
As long as you can determine which two contacts energize the electromagnet, and which two contacts are the switch.... you can wire in a universal relay to get things going again.
   / Relay Switches 4720i #9
2006 Mercedes-Benz E350 Sedan (A51694)
2006 Mercedes-Benz...
2001 JUSTIN 14 MOTORCYCLE TRAILER (A53843)
2001 JUSTIN 14...
2017 FREIGHTLINER CASCADIA SLEEPER (A53426)
2017 FREIGHTLINER...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A53473)
2015 Ford F550...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A53843)
2011 MAGNUM...
