Reinforcement for FEL bucket
/ Reinforcement for FEL bucket #1
djw250
Hurricane alley (South Louisiana)
Mahindra 3510
I'm sure that a lot of you have done something like this. It only took me a couple of weeks to bend the top of my FEL bucket on my new Mahindra 3510, and I'd like to reinforce the top edge of the bucket and maybe add some hooks. My idea is to take a piece of 2 X 1/4 inch angle and weld to the top of the bucket, then weld some tabs to bolt on hooks on each end and in the center. Anybody have any suggestions or pictures of mods that you have done, please post them up.
Thanks,
Dave
/ Reinforcement for FEL bucket #2
There is actually a photo comparision of factory buckets from several manufacturers where we rated the buckets on various different criteria. If you care to search for it, it might help you.
The really heavy duty buckets that impress me the most are from New Holland, they have a heavy round tube welded under the top lip of the bucket that makes for a very stout upper lip. I'd suggest you will get a lot more strength from a 2" or 3" pipe than you will from angle iron. If you want attachment points or hooks on the top lip, you could easily weld those up after the tube is in place. Just my thoughts.
I use a New Holland TC24 and a Kubota B2910. The B2910 is the bigger machine, but the bucket is lighter duty. I welded hooks on the upper lip of my TC bucket and with the way NH reinforced the bucket I've never even thought I might bend it. I've lifted and carried 18' steel car ramps with it that made the back end of the tractor feel light (even with a weight box attached) but never had a problem with bending the bucket lip.
/ Reinforcement for FEL bucket #3
The method most often used fo hooks is to first weld a reinforcement plate (maybe 3" x 5") and then to weld the hook to the center of the plate.
Plate would preferably be a guage thicker than bucket stock.
This spreads loads.
I have 3 hooks on my bucket (one center and 2 near each corner) , actually had the rear 'off the ground' under load strains without any ill effects to bucket.
The bucket otherwise being an engineered item could simply 'sport' the war wounds with no ill effects and I doubt if you'd need to add reinforcement as with hooks that would not happen again.
My bucket has folded over flanges on top lip and true to form I have a few 'kinks' from hooking the chain hook on the lip as well.
Hooking on the lip is also a dangerous practice as the chain hook can slide off to the side under load and result in a tipover or injure a helper if nearby when the load shifts.
My opinion.
/ Reinforcement for FEL bucket #4
My bucket sounds similiar to the one you describe. My dealer when they sold me the tractor, has a policy to weld a strip of metal ito that gap on the top of the bucket. this certainly reinforced the bucket. Never have I had a problem with it. The hooks were than welded on, and now that I look at them I see they use a clevis hook and neetly trimmed off the clevis section.Looks very sleek.
Allan
/ Reinforcement for FEL bucket #5
Use 1-1/2 in channel on edge. Weld it to the top edge and then cut 3/8 in slots every couple feet. You can then hook your chain in whatever slot you need and you won't need chain hooks. I have used this setup for years and it works excelent. It is very easy to adjust your chain to just the right length.
Leaddog
/ Reinforcement for FEL bucket #6
Here's what I have on the LA302 FEL for my B7510HST. The dealer welded a 1/4" thick reinforcing strip to the top of the bucket before welding the chain hooks.
/ Reinforcement for FEL bucket #7
If it were me I would use a good sized square tube on top of the bucket also bolted to the sides plates of the bucket. That way if you decide at a later time that you want an add a bucket grapple you already have the base installed.
Thanks for all the good ideas. I think I'll modify my original idea to include the square tubing. I just happen to have some 2" square tubing on hand, and that gives me some other ideas as well.
/ Reinforcement for FEL bucket #10
I used 2x2x1/8 angle on the LA402 on my Kubota B7800 and welded 3 hooks to that. Works for me.
/ Reinforcement for FEL bucket #11
Hi Dave,
I just welded 2 grab hooks onto my bucket this weekend. They are welded to plates, which are welded to the back of the bucket. These are near the top lip, but not on the top lip. I plan to add a plate across the the top of the bucket to help with the stress if needed, but the top lip of this Koyker is pretty hefty.
/ Reinforcement for FEL bucket #12
I did this around the time this thread was active but didn't get around to taking photos until a couple of days ago. /forums/images/graemlins/grin.gif
I used a piece of 2" x 3" 1/4" angle to reinforce the top edge of my 60" Light Materials bucket on the LA402 of my B2910. The angle pretty much fit perfectly giving a level flat surface if I decide to install a grapple later and need a place to set some square tube for it.
I also cut off the original hooks that the dealer had installed, which were the clevis type, and installed a proper pair of weld-on ones which I had picked up at AW Direct awhile back. I re-used the 1/2" base plates that my dealer had welded the original hooks to. I did have to do a pair of cut outs in the nagle to accomodate the base plates.
/ Reinforcement for FEL bucket #13
Right side of the bucket. Note that the hooks are placed so that they are in line with the loader arms (my dealer though that this would minimize the likelihood of tweaking the loader)
/ Reinforcement for FEL bucket #14
Entire rear. The big thing in the middle top of the bucket is a piece of 1/2" plate that the dealer installed. It is to prevent loose materials in the bucket from pouring back (onto the hood of the tractor) when the bucket is raised high and curled all the way back.
(When I bought B2910 my dealer had almost new L series in his rental fleet .... without the plate on the top edge of the bucket. Someone had taken it out and repeatedly dumped gravel onto the nice new hood. The tractor was in great shape when I saw it .... except for all the paint chips on the hood which were now rusting away)
/ Reinforcement for FEL bucket #15
Front edge.
Hmmmm ...... looks like like I didn't quite get the last load completely dumped. /forums/images/graemlins/shocked.gif
/ Reinforcement for FEL bucket #16
Interesting mods.
How do you keep the chains in the hooks, with the hooks angled backwards? For me the chain would fall out. I'd want my hooks in front, so gravity holds the chain in the hook.
--->Paul
/ Reinforcement for FEL bucket #17
Nice modification Randy, and those are some nice looking beads too.
/ Reinforcement for FEL bucket #18
</font><font color="blue" class="small">( How do you keep the chains in the hooks, with the hooks angled backwards? )</font>
It's easy - I hook to the chain about 1' or so in from the end - the short end of the chain is then draped over the front lip of the bucket along with the longer part. The weight of both keeps the chain seated in the slot .... haven't had a problem with it yet in almost two years.
/ Reinforcement for FEL bucket #19
Thanks Mike. /forums/images/graemlins/grin.gif
/ Reinforcement for FEL bucket #20
Good job and nice welds /forums/images/graemlins/cool.gif
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
2025 GIYI GY-PG72C 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A59228)
2025 GIYI GY-PG72C...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
Kubota M5-111 (A53317)
2019 INTERNATIONAL 4300 26FT BOX TRUCK (A59905)
2019 INTERNATIONAL...
