Forks Regular or Heavy Duty Forks??
   / Regular or Heavy Duty Forks?? #1
Fox Lake, WI
John Deere 3720
I have a 3720 and want either 2000# rated or a 3500# rated fork setup. Will a 2000# set bend and twist with a 3720 where a 3500# might not. I will lift heavy stuff and poke and dig and whatever with the forks. I won't baby it, I am sure. I know a heavier set will be stronger but would a 2000# work with a tractor of this caliber:confused::confused::confused3::confused3:?
   / Regular or Heavy Duty Forks?? #2
not seeing the forks i cant tell you either way.we have front an rear hay forks,an they are heavy son of a guns.then i have a set of light hay forks on the new tractor.an i know if pushed to far the forks will bend an break.
   / Regular or Heavy Duty Forks?? #3
i would say that if you intend on using these to poke in to the ground for what ever reason to go heavy duty but the extra weight of the bigh ones will diminish lift capacity so it all depends what you are going to do also cost
   / Regular or Heavy Duty Forks?? #4
I think by asking you have answered your own question. :thumbsup:
   / Regular or Heavy Duty Forks?? #5
I have 300CX and I think lift capacity is ~1500 LBS, That's on a 4310.
If yours is the same then 3500 is way over kill.
I have the Horst set, can't remember off the top of my head But I think they are ~ 2000 capacity. I do not baby mine and use them for far more than moving pallets.
Don' think you will bend or twist 2000LB forks with the 300 loaders capacity, How many HP with 3720?.
JB.
   / Regular or Heavy Duty Forks?? #6
Bought a quicktach for mine. Swore I wouldn't misuse and abuse it by using it for an unintended application (right tool for the job, etc).
Guess what my 2nd use was for? Digging out a concreted chain link fence stump. Bent a fork (slightly). Later, tore a strap off of the top of the frame (can't remember what I was doing).
You can use a heavy duty unit for light work, but not a light duty unit for heavy work.
3 PETROLEUM SUCTION 150PSI (A55745)
3 PETROLEUM...
2021 KENWORTH T270 (A55745)
2021 KENWORTH T270...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
PUSH MOWER (A55745)
PUSH MOWER (A55745)
1985 Miller Wildcat 350-D Welder (A54811)
1985 Miller...
2013 Audi A6 AWD Sedan (A53424)
2013 Audi A6 AWD...
