Regret not getting a backhoe for my tractor
   / Regret not getting a backhoe for my tractor #12
My two cents worth I start out with a BX tractor with a backhoe on it. I agree with what’s been said before it adds more length to the tractor which makes it less maneuverable. Additionally, it is not fun to take on and off and actually it can be very dangerous. It’s a heavy piece of machinery the backhoe that is and not well balanced to larger tractors And again found I needed something to dig holes, but I didn’t want to backhoe for its somewhat restricted. So I bought a small excavator very simmer in size to the backhoe on a BX or B and quite honestly I’ve been very happy with it. Yes, it’s another piece of machinery to maintain however, it’s much more flexible than a backhoe can get into tight spots and serve me very well. You don’t have to stop reset up. Move the seat dig a hole stop move the tractor. Set up. Dig a little bit more good example I dug almost 200 feet of trench 12 inches wide 12 to 14 inches deep in about an hour and a half with my little excavator cause I could dig and move and dig and move , I can dig down just under 6 feet take out small tree stumps and do about everything I want and as I said, it’s very flexible and my tractor shorter overall length so it is more maneuverable my opinion
   / Regret not getting a backhoe for my tractor #13
Greedy no, just opportunistic and willing to help someone in need.
Providing a container sufficient for someone to give you over 100 million 1$ bills is opportunistic indeed.
American $1 bills? Nah, I'll load him up with Iranian currency (cheapest in the world). 13 yards should be about $16,000 USD. Which is about the average cost to do or fix anything around here. 🤣
   / Regret not getting a backhoe for my tractor #15
Just as so long as you stack them nicely like this. The, ever so considerate, Iranian govt has decide to slice 4 zeroes off their currency to make the populace happy. Iranian currency inflation since 2018, if memory serves, is running at average of 38% per year.
Someone just purchased a single piece of bread.
   / Regret not getting a backhoe for my tractor #16
I know the intent of this thread was for laughs, but since we really are talking about BH attachments now, to me it seems like unless you bought one as part of a package deal with your tractor, they're crazy expensive to buy and equip your tractor with later on.
You fellers would know more than me, but adding one later being the case, it would seem to make more sense to buy one of those imported mini excavators instead. I've seen them online with diesel engines for $7K and air cooled gas engine powered for $5K. They'd almost pay for themselves if you had a bigger job or 3 to do.
   / Regret not getting a backhoe for my tractor #17
I could heat my home in winter.
Regarding a backhoe, a 5 ton or larger excavator can do some satisfying real work.
   / Regret not getting a backhoe for my tractor #18
Burning Rials is probably cheaper, by the ton, than paying for pellets or cured firewood.
The current 2024 foreign exchange on Rials is officially 42,xxx Iranian Rials to ONE USD but actual rate in use is 767,xxx to one USD. xxx used in FOREX info because the inflation rate is so high its losing value every minute you hold onto it.
On another note more appropriate to TBN, an excavator is a wonderful and useful toy because it can do work the M59 can't do. Had this delivered after Hurricane Helene rampaged thru NC. Next week it goes to friends house to scrap Helene debris off acre of land and replace the missing bridge
   / Regret not getting a backhoe for my tractor #19
A backhoe is a great thing to have but it all depends on your usage. They are not just for digging.. If you have an hydraulic thumb they are amazing for lifting things into place or removing things!!
It is very important to make sure you get one with a sub-frame if you do decide on one for your tractor.
I have used mine quite extensively at times but then it will also sit for long periods of time. I decided on getting it instead of an excavator because I did not want to have an entire other machine with another engine and a drivetrain to sit around and have to maintain. Therefore the removable backhoe was for me the best option.
Just my 2 cents. I hope this helps!!
I did the same thing and for most of same reasons.
A backhoe is very handy for lots of chores and if used reasonably & with a sub-frame it will not hurt you or the tractor.
The cost was worth it to me just to have it available when needed.
To the OP, I don't think you really haven't lost anything by waiting to get the proper backhoe for your tractor.
rScotty
   / Regret not getting a backhoe for my tractor #20
It sounds like the OP needs a reverse GoFundMe. Instead of digging a hole to throw his money into, he can send it to us for disposable.
JOHN DEERE 544K WHEEL LOADER (A52709)
JOHN DEERE 544K...
LOT OF ELECTRIC HEATERS (A58374)
LOT OF ELECTRIC...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58018)
2019 FREIGHTLINER...
2020 4-Fuel 800 Gallon Fuel Tank, Model 4F-838, S/N 4F-838811/20, Nominal Capacity, 838 Gallon/3172 (A59076)
2020 4-Fuel 800...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52709)
(INOP) 2019 KUBOTA...
2015 Ford Focus Sedan (A56859)
2015 Ford Focus...
