ReGen YT
/ ReGen YT #61
I just watched the Yanmar Academy Regen videos and looks like regen is scheduled at 50 hrs then every 100 hrs, so mine was on schedule.
/ ReGen YT #62
I wish renewable diesel was available up here in WA state. Five years ago it was, then it became harder and harder to source. My local fuel distributor stopped getting it due to the distance they had to go when sourcing it. So those in Calif. are lucky, perhaps also Oregon but WA. no way...sigh.
/ ReGen YT #63
Renewable diesel made my Branson run noticeably better. It starts easier and runs cleaner when cold. Less smell out of the DPF too. It's a continual low temp regen system and I can't get the DPF clogged data from the data recorder so I can't tell how much better it is for the DPF. But it runs so much better on renewable that I'd use it even if it had no other benefits.
My 2022 Silverado HD with EFI, DEF and all the other stuff modern diesels over 75hp have, doesn't seem to care which fuel it gets. It regens at 800 miles no matter what the DPF's condition is or which fuel I have been using. I think that's programmed in because it can happen when the DPF is less than 50% clogged.
Currently I think most stations in CA have renewable diesel. It's often not marked as such so it can be hard to tell. I found an app and web site that shows stations that have it.
There's only a couple listed in my part of Oregon, but Oregon does have a program to encourage it's use so hopefully it becomes more wide spread.
2013 Mercedes Benz E350 AWD Sedan (A59231)
2013 Mercedes Benz...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
2020 Kinze 3505 High Speed 6/11 Planter (A61307)
2020 Kinze 3505...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
