Regen cycle
   / Regen cycle #1
uptaker73
Morganton, NC
RK 37, John Deere LX280 John Deere Z535m John Deere 160
Experienced my first regen cycle with the RK37 at 32 hours, It didn't perform as the manual suggested. I applied the brake and hit the ACK button and nothing. I ended up raising the rpm's up to 2200 manually. The regen light did eventually clear after roughly 30 minutes. Just wondering if anyone else have had this issue?
   / Regen cycle #2
Yes, same for me. Couldn't figure out what I was doing wrong but definately not working as the manual suggests. Figured I was just doing something wrong or misunderstood something.
   / Regen cycle
Hopefully RK Tractor guy can answer this issue.
   / Regen cycle #4
So your dash illuminated with the engine warning light (exclamation point) and regen request lamp, indicating that you needed to manually start the operation?
And when you say the regen lamp cleared, are you referring to the exhaust temp lamp?
Curious to know what to expect and a little confused about the process as described by the manual.
It states that the exhaust temp lamp will illuminate when the DPF is at 400+ degrees. It also states that automatic regen occurs whenever the exhaust temp lamp comes on during work.
So, if all it takes is 2200 rpm for an extended period to achieve 400 degrees at the DPF, wouldn't the tractor be regenerating anytime you have the rpms above 2200 for a decent amount of time? Or is there something special that occurs during regen that gets the DPF that hot, meaning the DPF cannot achieve 400 deg. via higher rpms alone?
   / Regen cycle
When it happened the first thing that grabbed my attention was a different smell from the exhaust. I assuming where it had injected fuel into the filter to burn. That's when I looked down and noticed the Regen indicator was on. And yes it showed an temp with the regen symbol. Very confusing for me as well when it happened. You will smell it before you see it!!
   / Regen cycle #6
Maybe not i'f you are in a cab. I noticed the light and it didnt respond to the button press as expected. I was in the middle of a job and didnt recall all of the details of what was in the manual except I need to push that button and then let it complete. I dont recall if it went out first or of it went out because I shut it off eventually.
   / Regen cycle #7
You only have to push the button if both the engine light and regen request light illuminate. If just the exhaust temp light comes on, then the process is happening automatically.
Is everyone saying they got both engine warning and regen request lights?
   / Regen cycle #8
I only got one light but rpms were not up automatically
   / Regen cycle #9
Regeneration does not commence until the DPF is hot.
In cold weather it can take awhile for DPF to pre-heat prior to regeneration actually starting.
If you are working, the DPF must be continually hot for regeneration. If the temp drops, the regeneration ceases and has to be started again from beginning, not from when it stopped.
I expect the cold weather is your problem.
   / Regen cycle #10
If you are working, the DPF must be continually hot for regeneration. If the temp drops, the regeneration ceases and has to be started again from beginning.
For me this was some time ago when it was warm outside. I'm sure I eventually turned off the tractor when nothing ever seemed to happen aside from a light. The next time I started it up there was no light. I doubt but its possible my rpms where up from actual work being done and it completed?
2014 Ford Escape S SUV (A48082)
2014 Ford Escape S...
1996 Ford F-350 Mason Dump Truck (A48081)
1996 Ford F-350...
Hustler Raptor Zero Turn Mower (A50860)
Hustler Raptor...
2005 Ford F-250 4x4 Ext. Cab Pickup Truck (A48081)
2005 Ford F-250...
2014 Chrysler Town & Country Touring-L Wagon (A50860)
2014 Chrysler Town...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
