Arber
- Joined
- Nov 16, 2025
- Messages
- 1
- Tractor
- Ford 3000 2.9L 1968 10 speed Made in England
Hi, everyone I am new here and have been having some issues with my Ford 3000 tractor.
Here goes>
The tractor refuses to start at 12v and basically cranks forever(there is no smoke while cranking or even an attempt to start) however at 24v(two 100AH batteries in series or 24v) it starts right up! Yet it doesn't smoke even when it first starts or when pulling things or even when punching the gas... it simply never smokes!
Now I have rebuilt the starter at a local starter machine shop thinking that is the issue but nothing really changed really it cranks the same like some videos I have watched on youtube so there is no problem there also compression should not be an issue since it works very well and pulls great once started and running but still doesn't smoke, it has a down exchaust pipe and the pipe is in good condition and not clogged.
My current suspicion is the injection pump which is a Lucas CAV DPA pump and it does have an issue where if you run it out of diesel bleeding it is a literal nightmare which does point out to the pump or rather the vane pump!
It has all new fuel filters as well as clean everything lines tank everything is spotless. Is there hope that I can fix the problem myself or just get the pump rebuilt and stop pulling my hair or could the problem be elsewhere!
Previously I have owned various Massey Fergusson tractors and none have had this problem!
Any suggestion feel free!
Here goes>
