fried1765
Super Star Member
- Joined
- Jan 6, 2015
- Messages
- 10,159
- Tractor
- Kubota L48 TLB, Ford 1920 FEL, 8N Ford, Gravely 12 HP "Professional", 48" SCAG Liberty
I'm just the opposite. I only use my back blade to pull gravel out of the ditches after the rain washes it there. For everything else I use my grading scrapper. Does yours have ripping teeth? I use them quite often. Places like where pot holes are forming I'll rip pretty deep and plenty wide on both sides. When I'm forming the crown I just extend the side link on my 3pt. If it was me I would remove the organics. Grass forms dirt which is mud when wet. Your driveway looks flat, if so I wouldn't worry about getting your crown too high unless you have problems with flooding in low spots. You just don't want water to form a pool on your driveway (It'll become a pot hole). Ideally you want the driveway to shed water off of it but slowly. If it does it too fast it'll carry the gravel with it. If not fast enough then the standing water will cause problems. I would put enough gravel down so your driveway is about an inch higher than your ground and the crown maybe an inch or two higher than that. If you still have problems you can build it up further. The locals around here usually just call it crusher run, not 1 1/4" minus.
A 2" crown on a 12 ft.wide (?) gravel driveway.
1" per 6ft. is nearly flat, and the edges would be only 1" above the natural ground level?
Not a great plan, for the Oceanic climate of the NW Washington area.
That pitch might work well in Southern Nevada, or the Gobi Desert.
Crushed gravel has many different descriptions in parts of the US.
Crusher run, 1-1/4 minus, 3/4 minus, Stone dust (usually only very fine), Crushed stone #411, 2B crushed stone, Limestone (type),..... and there are many others.
