REF: headachers Kioti warranty issue
/ REF: headachers Kioti warranty issue #1
rapracing
Pennsylvania
KIOTI CK30HST, RTV-X1100C
I am wondering how much of a problem Kioti is having with the 2375 valve assembly. Mine was replaced in the first week because it leaked to the ground in about 30 minutes. The new one seemed to work better for a couple of months (6-8 hours) but now leaks to the gound in 60-75 minutes.
I was told it is about an $1800 valve. Not sure if that would include labor. I hope it I never have to replace one after the warranty runs out. From what I read there seems to be several who may be having the same problem.
/ REF: headachers Kioti warranty issue #2
Invoice I have list $1747.20 for Bc01-0100-p control valve asm. + labor. I have ask several times what is normal leak off ,still don't know . good luck jim
/ REF: headachers Kioti warranty issue #3
Mine seemed to leak not as bad as yours, but it would probably drop 1 to 2 feet in 3 to 4 hours. I would notice the most when I went to go use it after a few days, it would be down quite a bit. I have to swing it 90 degrees to be able to fit it all the way in my shed, so after a few days it would be resting against the side of my shed. Now I've been able to kind of catch it on the outrigger. Who knows, I'm probably screwing something up with the outrigger now. Hopefully I'll have time to contract the dealer and see what they say. I'm under warranty until late October or early November so hopefully if it really goes it goes before then.
/ REF: headachers Kioti warranty issue #4
Are you guys sure this 3-4 hour/1-2 foot leak down is abnormal for a backhoe? Seems to me it would not interfer with function at all and that the only concern would be if it seemed to be getting worse. I've only owned one backhoe so am just curious as to what "normal" is.
/ REF: headachers Kioti warranty issue #5
I'm not sure about a small backhoe, but I know most of your larger backhoe's have a boom lock. From what I understand this prevents the boom from leaking down. I would imagine it also helps with wear on the boom cylinder. I have never seen any backhoe not leak down. Case, NH, JD, JCB all of them that I have used leakdown.
/ REF: headachers Kioti warranty issue #6
</font><font color="blue" class="small">( Are you guys sure this 3-4 hour/1-2 foot leak down is abnormal for a backhoe? )</font>
My Rhino backhoe has always leaked off about the same amount.
Normal for a backhoe as far as I'm concerned.
Works good when I'm using it and thats what matters (at least to me).
/ REF: headachers Kioti warranty issue #7
Jim
I had sent you a PM about the invoice, not sure if you got it.
As far as the price for the control valve assy it lists for $1911.00. As you all know nobody pays list.
Here we typically charge slightly more than our cost on parts that expensive.
Kioti didn't pay the dealer 1747.20 either, it was probably much less.
Also just a note for the future. There are 3 possible valve bodies for the KB2375 & K2376 backhoes.
Nimco #BC01-0100-P
Dinoil #BC03-0000-P Hose Kit BR02-0100
Hanil #BCR04-0000-P
(shhh~use the Hanil)
check the picture attached as to where to check for a possible leak, occasionally the teflon washer and o-ring don't seat right.
/ REF: headachers Kioti warranty issue #8
I've read many posts that stated the members' backhoes leaked down some over time. Mine will drop the stabilizers more than the boom, with only a small amount on the boom over night. The staiblizers will come about half way down in a half day.
When I have the BH on, I park with the stabilizers locked and the bucket on the ground, so it doesn't matter.
When I'm using it, I occasionally have to run the stabilizers back up to get through a tight space, but it's never really a problem and seems to be pretty normal.
Now if it happend a lot faster, I would begin to worry. If the fluid is not leaking and the leak down is not really a bother, I don't think there would be any problem.
john
/ REF: headachers Kioti warranty issue #9
I have a Kioti 2385 backhoe (have had for about 2 years now) and the boom has always leaked off. If I don't put the boom lock pin in, then it will leak to the ground in probably about 20-30 minutes. I did not find this odd as the old John Deere backhoe I had did this (quicker than that, actually), and the two rental backhoes that I have used in the past (A John Deere 310 and Kubota L39) also leaked down rather quickly. I just thought (mistakenly, perhaps?) that that is just how they are. As mentioned, the Kioti has a boom lock, the old JD used a chain to lock it up (OEM, not my invention) and the JD 310 had a boom lock (I can't remember about the Kubota - it has been several years and I only used it for a day).
Anyway, the backhoe functions perfectly while I'm using it, adn the boom lock pin eliminates leak down when I'm not, so unless the valve completely fails, I hope to never have to replace it.
Good luck to everyone with their equipment.
/ REF: headachers Kioti warranty issue #10
Hi,
As Becky has mentioned, there are 3 valves in use by Kioti. No one of the suppliers could supply kKioti with the numbers that they required.
All three valves are able to be repaired with a only a few seals, as she has also mentioned. It is unusual that the valve would need replacing because the only thing you can't fix is the machining. During warranty Kioti will sometimes just switch out the part because they can save on labor.
Besides the 2 seals mentioned by Becky I have found that when driving around without the BOOM PIN in place the seal in the Boom cylinder can be folded over from bouncing and will allow oil by the seal causing it to leak down. This also has a repair kit available.
It is a pain, but it is also very important to eliminate the bouncing weight on this system by resting the boom onto the PIN at the base of the BOOM.
Any backhoes I have ever worked on have some leak down when not locked. As long as it does not effect performance you should be OK.
KiotiDave
/ REF: headachers Kioti warranty issue #11
My KB2375 acts as KiotiJohn mentioned. Stabilizers drop much more quickly than the boom. I just use the pin lock on the boom when not in use and lock up the stabilizers.
I didn't know there were three valve units used on the bh. This leads to another question. My left stabilizer will not feather with weight on it. If you have it down with a little weight and want to go a little farther to level the tractor, as you feather the control for a little more, the arm will come up. You have to push the control farther forward to get down movement. The stabilizer does not bleed off with the control centered. The dealer said it might be the load check valves and ordered both of them. Looking at the parts manual diagram, I haven't a clue as to where they go. Does anyone know if this is the problem and if I split the valve unit, will I find them. I had removed all external fittings and plugs and saw nothing like the parts he gave me. Maybe my manual and the parts are for another brand of valve. The dealer doesn't really seem to excited to dig into it and said he has never had a control unit apart.
Is there a way of telling which one is on the machine? The first one that was there had shorter main levers than the current one. The new one main levers are probably 11 or 12 inches long bent out about 1/3 of the way up with straight down rigger levers. So far this one has not progressed to the point the origional did (time wise) but it does leak off, in my opinion, rapidly.
Thanks
/ REF: headachers Kioti warranty issue #13
I'm gonna combine my post and Wallace's from a different discusion and see if it makes any sense.
"Also just a note for the future. There are 3 possible valve bodies for the KB2375 & K2376 backhoes."
Nimco #BC01-0100-P <font color="red"> If it has round boots with little blue rings on them it is the first one </font>
Dinoil #BC03-0000-P Hose Kit BR02-0100 <font color="red"> If it has square boots it is the second one
</font>
Hanil #BCR04-0000-P <font color="red"> If it has real long handles with a bend in them it is the third one. </font>
/forums/images/graemlins/grin.gif Sounds like what is on the machine now is the Hanil one. Thanks for the information. What ever the first one was it was bad. Don't know though. Can't see it now.
Traxmax Stand-On Track Loader Skid Steer (A59228)
Traxmax Stand-On...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
PALLET OF GOLFCART TIRES (A60432)
PALLET OF GOLFCART...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
