Reducing flow and pressure in hydraulic branch circuit
   / Reducing flow and pressure in hydraulic branch circuit #41
I'm not a math wiz, but having worked with disk mowers which use one way cylinders to lift a gravity to lower, I decided to follow their lead to slow down the speed of my log lift even though I am using a 2 way cylinder. (I don't have to worry about rusting the cylinder bore like single acting do.) I went to my local implement dealer and picked up a single reducing orifice to go inline between my valve and the 1/2" hose going to the base of my cylinder. It worked but as another poster warned, it whined and was too slow. I removed it & drilled the hole a little larger - 3/32". Now no whine but still too slow, I went to a 1/4" hole and found the speed/control I like.
   / Reducing flow and pressure in hydraulic branch circuit #42
This is hind site now, but you could have used 1/4 in hose to connect the cyl.
Splitter is complete and i gave it a test tonight.
I ran the aux in 3/8 hose. It slowed it down quite a bit. The wedge lift is fine for speed.
The log lift is a bit touchy but manageable if you feather the controls. I may add an orifice to the circuit if necessary, but right now it seems OK
Finished pics in the build thread.
http://www.tractorbynet.com/forums/build-yourself/219145-woodsplitter-build-timberwolf-clone-3.html
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A60429)
2021 CATERPILLAR...
2014 Chevrolet Impala Limited Sedan (A59231)
2014 Chevrolet...
Takeuchi TB016 (A53317)
Takeuchi TB016...
More info coming soon! (A56858)
More info coming...
2014 Grove TMS700E 60 Ton Hydraulic Truck Crane (A60460)
2014 Grove TMS700E...
