Backhoe Reduced power in backhoe unit
   / Reduced power in backhoe unit #1
Danadj
NE Florida
Ford 555D Backhoe, Ford 7700
It appears I have blown and o-ring or some other bypass spool because the backhoe is not as strong as it has been. It will not load up the engine when I put it in a bind like it should. The loader is still as strong as ever. Any ideas where to look first?
   / Reduced power in backhoe unit #2
Model of tractor and backhoe would be a great help
Sorry, thought my signature would explain that but maybe it doesn't show up-it's a Ford 555D 4x4 extendahoe w/ 4in1 bucket. The machine is in good shape and this is something that has recently come light while I had it rented out on a job.
   / Reduced power in backhoe unit #4
The main relief valve is in the loader valve. Since the loader is fine, I would assume the relief is ok.
As for the BH, if only one function is affected, look into a linkage problem (valve won't move fully), or a cylinder issue (bad piston seal) or a circuit relief valve that's NG.
If all functions are weak, then one of the many valves in the outlet end cap has failed. That's the cap on the lefts side of the valve stack. It has an unloader valve, and a back pressure regulator valve. Probably the unloader has stuck open.
All functions are affected including the outriggers so I'm going to the unloader valve you spoke of. Thanks and I'll let you know how it goes. BTW, I have a shop manual specific for an older backhoe (555) and I'll look to see how similar/different they may be in this regard like I've done numerous times before.
   / Reduced power in backhoe unit #6
I use to work on fork lifts many years back. I now work as an electrician. Electricity and hydraulics work the same ( Am I nuts ) , no you can not see either flowing only the results. So you have to measure the flow or pressure. Back to hydraulics I would suggest that you install a pressure gauge 0-5000PSI on the supply to the spool valve Tee it in.
This will show how much pressure the pump is delivering. Low pressure means the pump is unloading or worn out.
If you then Tee a o-5000PSI gauge on the boom/stick/dipper it will show how much the pressure is when you load that part.
So far we have not needed an expensive flow meter to measure flow. Speed of the machine under a high pressure means you have pump gpm's. With a low pressure gauge 0-100 PSI I think you can check your return line to sump ( assume ) it goes there there should not be more than 30PSI back pressure.
Check the hydraulic filter for clean. Silly question enough oil and correct type.Is there 2 pumps in the system suction line sucking air?
Craig Clayton
   / Reduced power in backhoe unit #7
The 555 is very different from the D series. You'd be better off with the correct manual. Good luck.
I'll get a good manual when I run across one. In the mean time I do have access to pressure gauges and may well check the pressures but I am certain it's a valve stuck or something of that nature.
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
Ford Super Duty Pickup Truck Bed (A55973)
Ford Super Duty...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56436)
2023 Kubota...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
KUBOTA 80" QUICK ATTACH BUCKET (A51406)
KUBOTA 80" QUICK...
toro reel master (A56857)
toro reel master...
