Red wire ? and voltage regulator on 187d
   / Red wire ? and voltage regulator on 187d #1
John_C
Kansas City
YM 187D
I have a 187d with the charging light on. Battery not charging. There's a red wire coming out of the wiring harness along with the + battery cable. This red wire has a plug-together type connection but there's no wire plugged into it. The positive battery terminal cable end has been replaced. Other then the large + battery cable there is no other wire connected to the + cable end.
Anyone know what this red wire is for and should it be connected to the + battery cable end? I've seen a lot of + battery terminals with a red wire coming off the cable end along with the main battery cable.
Also, anyone know where the voltage regulator on this thing is and whether there is a replacement at the local parts store or JDeere dealer?
   / Red wire ? and voltage regulator on 187d #2
The red wire is a hot wire to engage the front PTO, when one is installed. Do not connect it the battery.
The voltage regulator is probably what's bad and causing your tractor not to charge. It is located on the firewall and has fins on it, it usually is mounted with two Phillips screws. I don't know if J.D. will fit/work. But I can ship you one, contact me for price. Thanks, Gary J.
Loftness Mulching Head (A51573)
Loftness Mulching...
Hustler Zero Turn Mower (A51573)
Hustler Zero Turn...
1973 FORD 9000 TANDEM AXLE DUMP TRUCK (A52576)
1973 FORD 9000...
New Wolverine Skid Steer Tiller Attachment (A53002)
New Wolverine Skid...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2019 KENWORTH T680...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A51572)
2014 Ford F-150...
