Red Line Oils- why they're better
   / Red Line Oils- why they're better #1
TractorLegend
Platinum Member
Randle, WA
2012 DK 45HST SE w/ FEL
Red Line Oils- why they\'re better
Link
I found this most informative---better than the usual "Our oil is the best..." snippets on most other synthetic advertising.
I prefer Red Line in my equipment based on experience with it.
It is not cheap.
If you are happy with the fudge in your crankcase, I'm ok with it too. /forums/images/graemlins/smirk.gif
MikePA: Cleaned up long URL. Please review your message before posting it. It's simple not to do this. Just insert a descriptive word or two between the {url=http://whatever}<font color="red">Enter words here</font>{/url} instead of the entire URL. Replace parentheses with brackets in previous example.
   / Red Line Oils- why they're better #2
Re: Red Line Oils- why they\'re better
What's the specs on this here Red Line And who makes it.?
Maybe we all should try the Wildcat line.
My Fudge has been working well for many years!!
Egon /forums/images/graemlins/grin.gif
   / Red Line Oils- why they're better #3
Redline is a great oil no question about it.
For me the higher cost and there short drains "kill it" for me.
Spec's posted on their website
www.redlineoil.com
If you have oil tested to ensure your longer drain is legit, who says you couldn't do the same with Red Line?
   / Red Line Oils- why they're better #5
you can go longer but:
12 to 18K for normal gas
10 to 12K for stop and go for gas severe
and diesel is over 10K miles (standard drain for ext drains).
Fo me, approx $10 per bottle is to high for these intervals. Unless Amsoil goes higher, Redline is a no go.
Redline is about ~7.00 qt in Seattle area
   / Red Line Oils- why they're better #7
not bad. Again for me it needs to have the same intervals as Amsoil until I try it.
Plus I get amsoil for less then that! /forums/images/graemlins/grin.gif It helps to know dealers. /forums/images/graemlins/laugh.gif
   / Red Line Oils- why they're better #8
The Red Line oil is one of the most difficult oils to wipe off of engine components if spilled on them. I know this theory isn't very scientific, but if it clings to internal engine parts like it does the external parts when spilled on them, or even like it does the inside of my funnel, it is great stuff! I'm very impressed with it's performance. I've noticed about 8 degree cooler operating temps in my hot rod when moving from Royal Purple to Red Line racing oil.
My only objection is the high price where I live. About the best I can find it is $8.25 a quart. Amsoil can be had for about $2.50 a quart less for a very comparable product. So, that is why I use Amsoil rather than Red Line for the most part. That is a big difference per quart for something that is neck and neck on quality. I do not do extended oil drain intervals, so that part of Amsoil purported advantage has no benefit to me. The difference in price does have a benefit to me. /forums/images/graemlins/tongue.gif
   / Red Line Oils- why they're better #9
Brent, I have to agree that whatever the reasons, Redline certainly is different then any synthetic oil I have tried. It smells different, it adheres differently, it rolls off the dipstick differently, in short, it is indeed the most unique of any oil synthetic or conventional that I have used. While that is hardly an endorsement, it is interesting that it behaves differently then any other oil that I have experience with.
In life a company must do a certain amount of marketing to sell their product-namely giving the buying public the reason their mousetrap is better/different/more beneficial than the other companies. With Amsoil, their spin is the extended oil drain.
Its true. if you have your oil tested, and your engine isn't a gross internal polluter you may be able to extend an oil change interval if so desired.
If a company can explain in understandable terms with test evidence what makes theirs unique, thats good.
I have read Amsoils literature complete and think its good stuff (they have a cheaper 5000 series and I believe and their 8000? series if memory serves correct). The literature failed to mention whats left out in the 5000 series to make it cheaper but still so good. And I couldn't read what magic allowed their oil to make internal combustion shed less pollution into the oil thereby granting an extended drain benefit where no other synthetic is supposedly capable.
I think if tested you can do it with any quality synthetic such as Red Line.
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A55301)
Koyker Loader...
TEST BID LOT (A50775)
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A54607)
2013 KENWORTH T680...
2013 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54607)
2013 FREIGHTLINER...
