red dye in tran oil
   / red dye in tran oil #1
logankelly
winona mn
jd2520
read some posts that some owners put some red dye in hydraulic oil so they see it better in sight glass is that a jd product or where does a person pick it up at?
   / red dye in tran oil #2
Your JD dealer can get it for you if he doesn't stock it. It's a very small container, but it will do a large tractor so, for you 2520 try putting in only 1/2 or 1/3 initially. Save the rest for the next change.
   / red dye in tran oil #3
JD dealer can get;about $5.00.I put some in my Kubota.Problem was I didn't tell my Kubota dealer and they had thought I had put automatic transmission fluid in it!Well worth doing for sure.
   / red dye in tran oil #4
My bottle of JD red hydraulic dye was $12 or so off Amazon a couple years ago. Made the sight glass in my old L3200 usable. Made sure to mention it to the buyer when I sold it so they wouldn't wig out about it being ATF.
Less of an issue with the dipstick on my new L4060, but I might grab another bote at some point.
   / red dye in tran oil #5
john deere part number MT3668--put in in three tractors and it makes checking the hydraulic oil very easy
   / red dye in tran oil #6
It also makes identifying leaks very easy and only $5.31 per bottle at the Deere dealer.
   / red dye in tran oil #8
Oh, I used half a bottle in my L3200 & it was plenty. Went to used the other half a year or 2 later & found it all dried out. Not sure if it just goes bad or I didn't get the cap on tight enough or what.
thanks called it in should be at jd dealer today
   / red dye in tran oil #10
It would be nicer if it came in blue, so you would not confuse it with leaking red diesel fuel.
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
Kubota ZG327 (A50120)
2013 BMW X5 xDrive35i AWD SUV (A53424)
2013 BMW X5...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
