red dye in tran oil
   / red dye in tran oil #1
logankelly
Bronze Member
winona mn
jd2520
read some posts that some owners put some red dye in hydraulic oil so they see it better in sight glass is that a jd product or where does a person pick it up at?
   / red dye in tran oil #2
Your JD dealer can get it for you if he doesn't stock it. It's a very small container, but it will do a large tractor so, for you 2520 try putting in only 1/2 or 1/3 initially. Save the rest for the next change.
   / red dye in tran oil #3
JD dealer can get;about $5.00.I put some in my Kubota.Problem was I didn't tell my Kubota dealer and they had thought I had put automatic transmission fluid in it!Well worth doing for sure.
   / red dye in tran oil #4
My bottle of JD red hydraulic dye was $12 or so off Amazon a couple years ago. Made the sight glass in my old L3200 usable. Made sure to mention it to the buyer when I sold it so they wouldn't wig out about it being ATF.
Less of an issue with the dipstick on my new L4060, but I might grab another bote at some point.
   / red dye in tran oil #5
john deere part number MT3668--put in in three tractors and it makes checking the hydraulic oil very easy
   / red dye in tran oil #6
It also makes identifying leaks very easy and only $5.31 per bottle at the Deere dealer.
   / red dye in tran oil #8
Oh, I used half a bottle in my L3200 & it was plenty. Went to used the other half a year or 2 later & found it all dried out. Not sure if it just goes bad or I didn't get the cap on tight enough or what.
thanks called it in should be at jd dealer today
   / red dye in tran oil #10
It would be nicer if it came in blue, so you would not confuse it with leaking red diesel fuel.
Killbros 260 Seed Conveyor (A55301)
Killbros 260 Seed...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
2003 Walk-Behind Automatic Seed Spreader (A54811)
2003 Walk-Behind...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
2018 GENIE GTH-844 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-844...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
