Red Dye Diesel Fuel
   / Red Dye Diesel Fuel #1
project
Northern CA
Not sure if this has been brought up before. A local station is now selling red dye diesel fuel for off-road vehicles. Its # 2 diesel . The red dye is added so it cannot be used on-road. Its exclusive of federal taxes. Its quite a savings depending on the quanity you use. Here in CA, I'm paying $2.68 gal. It would be about .40 less. Any users out there??
   / Red Dye Diesel Fuel #2
I would buy it in a minute if it was here in Wisconsin.
Bob
   / Red Dye Diesel Fuel #3
Since you are in California it's also the new ULSD fuel.
Dyed or off-road fuel is quite common in most parts of the country. The only difference between it and what you would nornally buy for on-road fuel is the dye. Availability is not usually at regular filling stations but at the local Ag or fuel distributor.
This topic has been discussed dozens of times already.
   / Red Dye Diesel Fuel #4
Yup, the dyed diesel is the same stuff. Sometimes, it might be a higher sulfer rating...... but usually the same. Not sure about the new fuel for the 2007's on road.
You usually find it in areas w/ lots of Ag. Sometimes smaller farms prefer going to them then having fuel delivered.
   / Red Dye Diesel Fuel #5
Bob
I live in Wi. and buy it in Iola all the time, no difference except for the dye..
   / Red Dye Diesel Fuel #6
Thats what i use in my kubota. The last time i bought it i think it was 2.06 a gallon.
   / Red Dye Diesel Fuel #7
I should have made it clear, if I could find it in the Milwaukee area I would buy it in a heart beat (or two :D )
Bob
   / Red Dye Diesel Fuel #8
I have saved between 35 cents up to as much as 115 cents buy purchasing off-road diesel instead of gas station on-road diesel. The fuel depots selling the off-road seem to be more in touch with the daily fluctuations in fuel price.
A free barrel, an 11$ HF rotary hand pump, and I am saving money on my first barrel.
   / Red Dye Diesel Fuel #9
Red dye diesel is the same diesel as the on road pump. In some areas of the country it may be low sulphur not ULSD. But it works fine in a tractor. Make sure the station sells enough of the stuff to keep it fresh.
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2015 FREIGHTLINER...
2014 International PayStar 5900i S/A Flatbed Truck (A52377)
2014 International...
2017 Dodge Charger Sedan (A53424)
2017 Dodge Charger...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
