Recycling old implements - making them pretty
   / Recycling old implements - making them pretty #11
I have had pretty good luck with using a wire brush on a angle grinder and then follow with a "Rust Reformer" made by Rust-Oleum ( RustOleum.com ). Can find it at most auto parts store. The rust reformer converts the rust into some thing else (forming a black primer). I have used multiple paints onto this primer and they all seem to hold well.
Good luck with your projects.
Sometimes I do it the easy way--use a rust converter to change the rust layer to a tightly bonded layer that acts as a primer over which you can paint. Gemplers makes one brand of RC--there are others
Gempler's Rust Converter Success Stories | Gempler's
Here's an example. I restored an old Minneapolis Moline P3-6 grain drill last year.
The feed cups were rusted pretty badly.
I used Gempler's RC on the cup housings and the fluted feed cylinders. The black coating on the flutes is Gempler's. I sprayed the housings with cold galvanize spray paint to prevent more rusting.
I used that restored grain drill last month to plant 5 acres of Kanota oats. The drill worked fine.
Hey thanks to all for the great advise! I had the racks of the '97 F350 I just acquired painted at a local body shop & I'm pretty sure he talked about a 'rust converter' instead of sanding / grinding & painting (I told him this was a budget job). It came out GREAT.
I picked up (today from ebay) a skid steer plow that had been used one year & stored 2. The paint has mostly peeled off from being outside but all in all it really doesn't look bad. I will probably pull the hydraulics off it & replace them with a welded up pinned stop assembly - my plowing needs are really basic here at the house & a fixed angle will work fine.
I'll try to take pix as I go.
I really do appreciate all the info. Thanks again & hope everyone has a great & healthy new year!
   / Recycling old implements - making them pretty #13
I picked up (today from ebay) a skid steer plow... that had been used one year & stored 2. The paint has mostly peeled off from being outside but all in all it really doesn't look bad. I will probably pull the hydraulics off it & replace them with a welded up pinned stop assembly - my plowing needs are really basic here at the house & a fixed angle will work fine
Are you talking about just one fixed angle or a manually adjustable angle? Its seems kind of a shame to ditch the hydraulics especially if they are in useable shape. Do you have a rear remote? Have you scoped out what it would take to get the hydraulics hooked up? You could make a manually adjustable angle using the square tube with punched holes (I call it stop sign post). Replace the hyd cylinders with a tube within a tube secured together with a pin. I don't know, maybe this is what you already had in mind. :)
Hi John,
The tube within a tube is exactly what I had in mind. I won't do anything that can't be 'reversed' - I'll be able to put back on the hydraulics. I don't know enough about hydraulics to know whether I can use my tractor's or not but from what I have read here it doesn't sound like I can without changing the loader valve - Too much $$$ right now.
   / Recycling old implements - making them pretty #15
The other way to remove the rust is washing soda in water, a sacrifice rod, a container big enough to hold the item in the soda and water and a battery charger:eek: Hook the positive to the sacrifice rod, the negative to the item and let it go for a day or two. I think there is a post on here somewhere that this was done to a plow prior to painting
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
LOT: (2) 2-Wheel Dollies, Roller Stand, (3) Screw Levelers (A59076)
LOT: (2) 2-Wheel...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 Ford F-550 Crew Cab Truck (A54814)
2012 Ford F-550...
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
set of 4 sailun 11R24.5 tires (A56435)
set of 4 sailun...
