Recovery point metal thick enough?
   / Recovery point metal thick enough? #21
I think you will be fine. I would expect the pin to shear first.
I think you are right. That is one big honking chunk of steel to tear out . It would be different if it was hollow but if it was mine I wouldn't sweat it.
   / Recovery point metal thick enough? #22
Failure of the 2" bar is the LAST component of that "system" that will fail! (5/8 pin, reciever tube, reciever frame/mounting, bolts to the truck frame)
Run it!
   / Recovery point metal thick enough? #23
I would suggest taking the modified receiver to a testing lab, have them attach it to a solid mounting point with a pin though the new hole you drilled, and then apply 30,000 lbs of pulling force to the shackle. If it don't break then, you are good to go!!!! :)
   / Recovery point metal thick enough? #24
There's no problem with the receiver... and I'm not sure what you mean by "stinger"?
Out here in rural Oregon, the the part of a trailer hitch which slides into the receiver is called a "stinger". I was under the impression that it was fairly common terminology, but maybe not. We west coast rednecks are an isolated and inbred bunch...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2018 International Durastar 4300 Altec LR756 56ft. Insulated Forestry Chipper Bucket Truck (A55852)
2018 International...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
2022 TAKEUCHI TL12R-2 SKID STEER (A52707)
2022 TAKEUCHI...
12-Ton Hydraulic Bottle Jack (A55852)
12-Ton Hydraulic...
