I posted in Attachments but got no takers. I'm replacing all the sections and double guards on this old 451. I did it before 5+ years ago. What I didn't like before was I had to take a large pipe wrench and long heavy EMT tube as an extension to bend the guards up to meet the sections. I know this is probably wrong. This time I've got new wear plates and hopefully the sections will rest correctly on the guards.
Anyone have experience rebuilding the cutter bar on the 451? I've got the sections, the guards are coming Tuesday. I probably should have gotten the double hardened German ones but I ordered the cheap ones before I saw them. Search: 3 results found for "219120*"
Are those rivet tools worth the $90? I can hammer on sections pretty fast with my 225 lb anvil and 2 lb rounding hammer. I punch the old rivets out with a Diamond horseshoer's clinch cutter after I grind off the rivet head on the section side. The narrow end.
But where the sections are sandwiched between 2 bars I usually end up drilling them out, they don't co-operate with the punch.
