reconditioned or unconditioned?
/ reconditioned or unconditioned? #1
topdog
I am a hobby rancher. Three years ago I bought a Yanmar FX28D from a local tractor seller who was selling "reconditioned" out of his backyard shop. She looked a beauty and after reading up and educating myself on this forum, I bought it for around $10,000. It worked great for the last 3 years for mostly light duty work. In July, I moved dirt for about 2 hours and it overheated. The local tractor/diesel mechanic says the engine needs to be rebuilt. Turns out it was repainted and new decals, but now it shows extreme wear from a "stop leak" product, no thermostat, orange silicone on the head gasket, and I'm looking at a$2000 plus bill. All suggestions are appreciated. :mad::confused::eek:
/ reconditioned or unconditioned? #2
... moved dirt for about 2 hours and it overheated...."stop leak" product, no thermostat, orange silicone on the head gasket...
I think this deserves more troubleshooting before spending that much money. If it were mine I would start by bringing the cooling system up to spec, a step that would be included in a major overhaul anyway. Run a cleaning chemical to loosen crud in the block, remove the radiator and take it in to be rodded out, and get the right thermostat installed. Diagnose if there is a head gasket problem. (Coolant in oil, etc).
If this tractor is seldom worked hard and it isn't difficult to start, I think fixing the cooling problem would put off an overhaul for many years.
/ reconditioned or unconditioned? #3
I agree with California, at a minimum. You may have a bad head gasket. Diagnose this and if its bad, most likely all you will need is to replace it, maybe have the surface machined flat. If it runs and still has power ther is no need for a rebuild.
Thanks for the alternatives. The shop that my tractor now resides is trying to find information on this tractor/engine. The TractorData site shows this to be a 3 cyllinder, but in actuality it is a 4 cyl. What gives? Also, where would we find the serial number if it still exists? Thanks for any help!
/ reconditioned or unconditioned? #5
I believe the FX28D is equipped with the 4TNA78UN (four cylinder) engine.
/ reconditioned or unconditioned? #6
serial number is on the exhaust side of the motor on the valve cover. I think all the parts are available to rebuild this motor. I also really doubt you need a total rebuild. But it seems like the head needs to come off to figure things out.
Keep us all updated.
My shop foreman has had another mechanic friend look at the engine. With the head off, you can see damage that they classify as severe (crack, cylinders, rings, pistons,etc) Looking at a minimum of $1500 to replace parts and machine the block, cylinders, ... or at least $3,000 to stick a rebuilt engine back in the hole. I'll probably make a decision on Monday given my options. I am looking for an engine to replace with. I might be looking for (sob:()...a replacement tractor. Thanks for the posts!
south texas (Yoakum)
CLUB CAR  CARRYALL 6 (A65643)
CLUB CAR CARRYALL...
Hyster S50XL Forklift (A65579)
Hyster S50XL...
70in. Skid Steer Root Rake (A65640)
70in. Skid Steer...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
2006 INTERNATIONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNATIONAL...
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
