Recommended work lights
   / Recommended work lights #1
RayCo
Veteran Member
Chester County, PA
Kubota BX24, Case 580 Super L
HI group. The sun just went down while I was in the middle of digging with my BX24. I need to order some work lights. Anyone have any favorites to recommend? I'd like a set that can swivel to point out the back of the tractor as well as the front. I'd attach them to my ROPS. I believe I have 40 amps to work with, which if my memory serves me right, would allow me to go as high as 480W total. Don't think I'd need that though.
   / Recommended work lights #2
If I may...
Tractor Work Lights
The ROPS brackets at the top of this page are about the best thing out there for work lights. You pull two pins and you can move them around to anywhere you want. You can use any old light, but those with switches built in will be easier to wire.
bones1 said:
I have to compliment you on your website. One of the better ones I have seen,did you build it?.:)
Me or MessickFarmEquip? If me, I did build it and thanks! :)
   / Recommended work lights #5
Most of it. There are some other guys that contribute to the content. Thanks for the compliment. Its a challange to try and orginize so much data.
That's why you should outsource it to your fellow tractor enthusiast/ASP.Net MVP. :D
   / Recommended work lights #8
A couple trap-z 55w floods should light up a huge area for ya.
Soundguy
   / Recommended work lights #9
As far as brackets go, I went to TSC and bough 2 bolt on trailer tie town bracket and with a little persuasion, they fit over the top of my rops. I then just used some metal straps and carriage bolts to hold everything together.
-Scot
bones1 said:
RayCo, are you holding up a fry or index finger in the Arbys Wheelhorse pic?:)
I believe that's a finger that's close to the index finger. :rolleyes:
4 ft Plastic Feeder Trough (A53117)
4 ft Plastic...
SHOP TOOLS (A53843)
SHOP TOOLS (A53843)
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
BUSH HOG 1815R1 BATWING MOWER (A51247)
BUSH HOG 1815R1...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
American G-Model Pump Jack (A53473)
American G-Model...
