Recommended TLB combination for < $25,000??? *DELETED*
   / Recommended TLB combination for < $25,000??? *DELETED* #2
Re: Recommended TLB combination for < $25,000???
Just a clarification - do you really want a TLB? If you already know please pardon my explanation, but TLB generally means a complete package all set up with both attachments. You can also add an FEL and BH to most CUTs, but often the units in the TLB packages are heavier duty.
Here's one: http://www.kiotitractor.com/products/tractors/lk3054xs.asp
I have an LK3054, but it's not the factory TLB package, as it was not offered before the XS model.
Also, with some TLB packages, mounting the BH is more involved than with a standard CUT, sometimes requiring removing the 3ph arms, etc. I have no idea if that's the case with the Kioti LK3054XS TLB.
Personaly, I think you'd be fine with a more typical CUT, FEL, and BH. Oh, and plan on getting a Box Blade for the work you'll be doing, even if it's a cheap one from TSC like I have - they're worth every penny!
Please excuse my unintended misuse of abreviations. I don't nesessarily want a "TBL". I have in mind a compact utility tractor with the ability to easily attach and unattach a front end loader and a backhoe.
   / Recommended TLB combination for < $25,000??? *DELETED* #4
I just bought a new DK35 TLB and the price came to the $25,000 with tax. I ordered the unit with the loader and backhoe factory installed and the dealer even loaded the rear tires with Rim guard for added weight and traction. The backhoe is the KB2385 with an 18" bucket and has the digging depth of 8'6". So far I'm impressed with the machine and the digging abilty of the backhoe. Also as for the ease of disconecting the loader and backhoe they have it designed to disconnect with the removal of only two pins and of course your hydraulic lines. Unlike other models where the three point arms has to be removed to use and hook up a backhoe the Kioti dk35 3pt arms can stay mounted and doesn't interfere. I done alot of shopping and pricing before buying and found the Kioti tractor to be reasonable in price, quality to be up, along with a good waranty and 3 year zero interest, can't be beat...
UNUSED PE Industrial Stretch Wrap Rolls (A53117)
UNUSED PE...
78'' skeleton /rock bucket (A53421)
78'' skeleton...
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2005 INTERNATIONAL 9400I (INOPERABLE) (A53843)
2005 INTERNATIONAL...
