Recommended or required pto
   / Recommended or required pto #1
JimmyGM
Oh
ym2210
I have two implements that max at recommended 40 Hp
Tillers says up To 40 pto, mower just says 20-40 hp
Got a good price on a tractor with 46 pto
Is it too much or lower the rpms 0r?
   / Recommended or required pto #2
I wouldn't be overly concerned about being 6hp over the implement limit. For the tiller, I would make sure the slip clutch is adjusted a little on the low side (assuming it has a slip clutch).
Locking up a tiller with an improperly adjusted slip clutch can result in trashing the gear box, or tractor components.
   / Recommended or required pto #3
I don't think a little over will be any problem. Like RjCorazza said - be sure any/all slip clutches are properly adjusted.
I've seen/heard of lots of implements being trashed. NEVER because the tractor had too much Hp.
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A50459)
2007 FORD F-750XL...
1999 John Deere 566 Round Baler  Net & Twine, Reliable Performance (A51039)
1999 John Deere...
2013 Ford F-150 (A50397)
2013 Ford F-150...
2011 Nissan Titan SV 4x4 Crew Cab Pickup Truck (A50323)
2011 Nissan Titan...
(INOP) 2005 JCB 506C TELESCOPIC FORKLIFT (A50459)
(INOP) 2005 JCB...
SOLDERING IRONS, GLOVES, AND STANDS (A50854)
SOLDERING IRONS...
