Recommended multi-meter
/ Recommended multi-meter #21
One in #1 post is more than sufficient for average person doing miscellaneous measurement around vehicle and house/barn....
Have two digital meters one cheap, one expensive....Have two analog meters, one cheap, one expensive... But for automotive/tractor work (no computers) I grab this first.....
That can lead you to think something is ok but it is not. Some things like relays for flashers need a specific voltage, something over 10v. If you are in the dark under a dash and the bulb lights up you think it is good, but it is not as the stupid blinkers will still not flippin blink. So you figure it is the flasher, you buy another and it does the same thing. You can't take back electrical parts so now you just get another one, they are cheap enough, it does not work, well hell the light lights up. No way all could be bad. So you start looking for bad grounds....it has to be that right. Only at the end when you can't figure out why the stupid thing will not work do you run a new wire from the stupid battery straight to the flasher and it works. But the "12v" wire that plugs into the flasher will not work.
Most crazy thing I have ever found.
/ Recommended multi-meter #22
I've got an old Fluke that left the Army with me; it just works, so long as there are batteries.
/ Recommended multi-meter #24
I still have my old Fluke 77 that still works and a HP Logic Dart that measures dc voltage along with a digital logic analyzer.
/ Recommended multi-meter #25
I have a general purpose FLUKE. It's more than 30 years old but still does everything I need. Back that long ago there were not all the exotic ones that are available today.
/ Recommended multi-meter #26
Maybe for a newdie... Been doing electrical for 40 years in telecommunications and in retirement last 23 years.... Sort of know what I am doing.... With test lamp a dim bulb is low voltage, a bright bulb is high voltage (12 volt systems) ....Just like learning to read a meter....
/ Recommended multi-meter #27
You know I'm an old electronic technician when I have a Fluke 11 like this on ebay. It works great and measures capacitance.
An analog meter I use also to see changing voltages or resistance, otherwise you're just watching numbers flash.
/ Recommended multi-meter #28
I started my career with a Simpson 260. 😁😁 Standard issue in the US Navy.
/ Recommended multi-meter #29
USAF electronic tech here, then aerospace electronic tech and then electrical engineer.
/ Recommended multi-meter #30
If you haven't bought anything yet I have a couple of near new meters. One is an Innova, Meter (click on link) Don't think it's ever been used, 60.00 shipped w/ insurance
the other I'm not sure of the brand right now possibly a KAL? 30.00 shipped.
The Innova is literally new. can get pic's if interested. message me here or at
T&M Automotive: Muscle Cars, Street/Hot Rods and Classic Cars NOTE: email is at bottom of page ;)
/ Recommended multi-meter #31
I have two Flukes and an analog with the old school needle. The needle is handy at times, like when tuning my generators.
Goe duck I have a bunch of digital meters, cheap and expensive. But I’m going to find me a good a anolog big meter. I just like them best
/ Recommended multi-meter #32
Goe duck I have a bunch of digital meters, cheap and expensive. But I’m going to find me a good an analog big meter. I just like them best
I agree. Flashing numbers are hard to follow at times. I like to have both, but the needle is very useful at times.
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
(2) UNUSED 420/85R34 TIRES ONLY (A64280)
(2) UNUSED...
2006 Hitch and Trailers Inc. 12ft S/A Utility Trailer (A61574)
2006 Hitch and...
2000 International 4900 Tandem Truck (A66285)
2000 International...
500 Gallon Hydraulic Oil Holding Tank (A61573)
500 Gallon...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
