Tractor Sizing Recommendations on size of tractor
   / Recommendations on size of tractor #11
One thing you are definitely going to get on this site is opinions/experience. Some good, some not so good. I know you stated you are not interested in renting equipment. However, you are going to find that the amount of digging you want to do is going to be very difficult, if not downright frustrating with a small tractor/backhoe on your property with slopes. Have you thought about buying a small mini-ex? You could use it until all of your major jobs are finished and then sell it. After that, get your permanent tractor.
I can't imagine needing anything more than a subcompact tractor on a 2 acre tract. I'd hire out the dirt work and save on the backhoe. How often do you think you will need to re-excavate your water line?
Contracting out requires someone with more money than I have :) As an example, the last time I had a waterline leak, to dig up 10 feet to find the actual leaking section, repair the leak and bury it back again was $3K. So for 3 more occurrences, the backhoe would pay for itself. The pond would be a 4-6 year project, digging it deeper as time goes on. Even if I line it or till in clay, it would still be dry between mid July and end of September. My part year stream dry's up in late June and usually doesn't start running again until mid/late September. I plan on shaping it with only a 1 foot depth the first year, then digging it deeper during consecutive years. The only purpose for the pond is to attract migratory birds.
OP
This link to Rock Crawler's slope mowing video is informative, he also posted an extensive TBN thread. His you tube channel discusses the BH experience w/ his machine as well.
I had seen this video before, but this time I noticed there was a "Part 2" video also. He took off his FEL, then everything worked fine. I don't have anything as steep as he was mowing and there is no need for any "cross-hill" mowing for me.
   / Recommendations on size of tractor #14
An SCUT would work if you have more time than money, but the next size up (i.e. Kubota B series or John Deere 2xxx series) might be a more suitable size for your short term and longer term needs.
   / Recommendations on size of tractor #15
^^^ That is what I would recommend to (buying a good used mini EX) with front blade and buy a small cut/scut for every thing else later
Sell the Mini EX when everything is done- for most of what was paid for it.
   / Recommendations on size of tractor #16
For that pond you're talking at least 400 yards of dirt moved. Do you know how high the water table is? Are there any springs in the area? I ask because trying to dig out a pond a bit each year "when it's dry" could be problematic of it's never really really dry. I strongly suggest you look into getting something someone with a big dozer to do it all in one shot, even if you do the other dirt with gradually this pond may not get dug in your lifetime if there are only a couple months of dry time on the surface...
I dug a test hole down to a 4' depth by hand (only 4' as I couldn't break through the second layer of hard-pan) in the lowest spot and it was dry as a bone in early July this year. The only water I have coming into that area is via a part year stream. When it rained, that layer of hard-pan held the water until it evaporated, so that might become the bottom of the pond, which would make the pond about 5' deep on average.
   / Recommendations on size of tractor #18
Having a toothbar on your bucket will definitely help your digging.
   / Recommendations on size of tractor #19
We just ended up with a 40HP compact with a FEL, BH, bush hog and some forks. We too have some digging to do for a new house - drainage, septic, trenching for underground cable for electrical and fiber optic, etc. Feel the BH will pay for itself.
We took the BH off for the first time and it was RIDICULOUSLY easy - so I can't see a downside to having one when you need it - other than the space it consumes in the shop. I completely get the "buy it / own it / do it yourself" instead of paying some folks to do it - with unemployment like it is - this stuff is getting amazingly expensive.
However, we also have 15 acres. You might need something this size - but that's not all that much property to need anything particularly large.
   / Recommendations on size of tractor #20
I’d take on a earth moving project with my CTL over my buddies 50 series mini excavator any day. The tooth bucket on the CTL digs like a beast and the mini sucks for moving dirt farther than it’s swing. If you have the 20k or so you were planning on spending and weren’t financing a used piece of construction equipment would get you a lot farther.
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A55301)
3-Point Hitch Root...
JCB 2145 (A47477)
JCB 2145 (A47477)
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
2018 Regal 29OBX 29ft Yacht with 34ft Trailer (A55853)
2018 Regal 29OBX...
