Rear Blade Recommendations For Rear Blade on Subcompact tractor
   / Recommendations For Rear Blade on Subcompact tractor #11
David,
How much blade you can handle really depends on your individual conditions. In your first post you mentioned "steep in places" I would submit that this will limit your ability to handle an aggressive blade. I missed that in my first post, revisiting your post and needs a lighter 5' blade would be the largest I recommend. I would also add that you will need to be able to use the blade while traveling uphill since you need to be able to put the material back to its original place.
   / Recommendations For Rear Blade on Subcompact tractor #12
My 5' blade I bought and used on my 4010 has all those features; I believe. It's a Frontier. Very light weight and cheap: $250.
Ralph
Ralph,
Which model? What does it cost today?
   / Recommendations For Rear Blade on Subcompact tractor #13
A woods RB60 has all the features you are looking for. You can spin it 180 degrees and it should not hit the tires
Ken
   / Recommendations For Rear Blade on Subcompact tractor #14
On my SCUT, the 5 ft blade worked fine for snow even with turf tires. I wasn't impressed with my skills at grading gravel with it, however. That is, in the spring when straightening out the mess of winter, the blade just didn't seem to perform up to my expectations. And yes, as another mentioned, the Rhino mold board has to be unbolted to get an offset. As to weight, I still say that the heavier the better and that the SCUT is perfectly capable of handling the heavier 5 foot blades. Maybe one of those grader scrapers would be a better choice in your case. Ain't tractor talk fun.:)
   / Recommendations For Rear Blade on Subcompact tractor #15
I'd recommend the 5' and one with good weight as well to be able to carry a good load. To just need it to keep the driveway in good shape I'd look at land pride driveway maintainer.
   / Recommendations For Rear Blade on Subcompact tractor #16
I think the a 5' EA value blade would be the best for you.
Some blades like a woods RB60 offset but you have to unbolt the blade and move it to a different set of bolt holes which would be a pain.
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
Genie GS-1930 19ft Electric Scissor Lift (A55851)
Genie GS-1930 19ft...
Polaris Side by Side (A50324)
Polaris Side by...
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A53422)
2008 Featherlite...
1994 International 3800 Bus (A55852)
1994 International...
Adams 8 Ton Weigh Hopper (A55314)
Adams 8 Ton Weigh...
