Recommendation for MAPP gas torch head
   / Recommendation for MAPP gas torch head #1
Blast Chamber
Wisconsin
JD 332
Hi guys,
I've been buying the Berzomatic trigger start torch heads (under $50) for when I use MAPP gas, but I've been through 3 of them now and they keep going bad. Not only do the self ignitors stop working, but the gas regulator goes bad as well and I can't get decent flow no matter what brand of cylinder I try.
I want to get a high quality unit that will last and am not opposed to paying more. I already have a large quantity MAPP cylinders in inventory so whatever I buy has to fit those. Anyone have a suggestion? The only brands I see on google are Bernzomatic (Lenox), Firepower, and TurboTorch. I like Lenox tools in general but they look the same as Bernzomatic (which I won't buy again).
Thanks.
   / Recommendation for MAPP gas torch head #2
Hi guys,
Thanks.
well from what I hear, turbotorch is the industry standard, one of those might be worth a try.
   / Recommendation for MAPP gas torch head #3
I use an old school conventional head and a striker to ignite. Dead simple and cheap.
   / Recommendation for MAPP gas torch head #4
Thats the way to go. you will find they use less gas also.
   / Recommendation for MAPP gas torch head #5
Turbo torch for me also. Had the first one 20 years and replaced it with same.
   / Recommendation for MAPP gas torch head #6
I have used both. The Turbo Torch is the only one that has " blown up" in my hand. I am gun shy of them. I go through several of the Bmatics a year. I just figure the cost of doing business.
   / Recommendation for MAPP gas torch head #7
If you mean for a small, like 14" or so tall tank, I usually go thru 1 small mapp torch a year. I have used many. I now use
a Turbo Torch STK-99 :thumbsup:
I will not be going back to this style;
   / Recommendation for MAPP gas torch head #8
I vote Turbo. Have a problem, They will work it out or replace.
   / Recommendation for MAPP gas torch head #9
I was under the impression that MAPP was out of vogue and not being used much anymore in favor of the small portable oxy/acet torches. You guys plumbers?
Ian
   / Recommendation for MAPP gas torch head #10
Ian
Depends. I use mapp for soft solder and oxy - acet for sil-phos work.
(not a plumber, but an HVAC guy).
Golf Cart (A51694)
Golf Cart (A51694)
Titan 5105 (A50123)
Titan 5105 (A50123)
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
