Recommendation for cement mixer
   / Recommendation for cement mixer #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
I've a (to me) major project http://www.tractorbynet.com/forums/projects/244190-another-concrete-drive-slope-project.html and a minor project, an entry walkway of about 30', and know if I get a cement mixer I'll use it several times a year.
Back in the early '60's I used one for two summers building a cement block foundation. Didn't need a gym. So I know how to use one.
This thread recommends the HF twice.
http://www.tractorbynet.com/forums/rural-living/149615-where-get-decent-concrete-mixer.html
It's $200 now. Lowes has one for $300.
Any TBN advice?
   / Recommendation for cement mixer #2
I just purchased the one from lowes 4+cubic, I'm happy with it. I like the idea of the extra rollers supporting the drum. Not only is it used for cement but it works great for mixing feed :D
   / Recommendation for cement mixer #3
Stand alone or 3 point?
3 point is sometimes like the girl at the end of the bar at 10:00 pm. The next day you wake up and say, "it seemed like a good idea at the time."
   / Recommendation for cement mixer #4
I bought one of the used HF mixers a few years ago and have used it often to mix concrete and mortar. No problems at all with it - and I was able to get it for $55 at a flea market (I did have to replace a few bolts that were missing, but that was it).
Good luck
   / Recommendation for cement mixer #5
I bought one of the HF $200. on sale and have used it a couple times and found that it did a good job.
One job I mixed 28 bags of 60# Sakrete (it holds 1 1/2 bags at a time or 1 90#). It mixes fast and with a wheelbarrow to dump in it went pretty well.
   / Recommendation for cement mixer #6
I used one of the ones from Lowes on a job a few years ago and mixed several hundred bags of various concrete products in it - a very good unit. I bought one earlier this year for myself and so far have mixed 75, 80 lb. bags of Quickrete and about 15, 50 lb. bags of surface bonding cement - still the same excellent unit as the other one. Yea, I can't see using one without those support wheels the Lowes model has, I would imagine the bearings in the gearbox would wear-out in no time compared to this one. I plan to have mine for many years to come. By the way, I mount mine on top of a pallet strapping the rear legs down and this allows you to pour into a contractor wheelbarrow without the unit tipping or anything.
   / Recommendation for cement mixer #7
I have one of the bigger HF ones (they sell two one 1.25 cf and one 3.5 cf )
I have mixed a lot in it now. I put 3 60lb bags in it at a time, mixes it no problem.
Very happy with mine.
   / Recommendation for cement mixer #8
I have one from Lowes. I took my time assembling it and used Locktite on every threaded fastener. This adds a lot to the life of the unit by preventing it from becoming wobbly when nuts & bolts loosen.
I have had it for over 4 years, one house build (over 1000 sq. ft. of rock veneer) and a few hundred square feet of block wall at a second location. It is still going strong. I rinse it out carefully after each use. I am thinking I have put 2 or 3 lifetimes of homeowner use on it. I would buy another one in a heartbeat.
   / Recommendation for cement mixer #9
   / Recommendation for cement mixer #10
Careful Assembly is more then half the battle.
I'm a big fan of Loctite Products... one tube will go a long way to keep things together and limit corrosion.
2016 CLUB CAR (A53424)
2018 VOLVO VNL DAY CAB (A52576)
2018 VOLVO VNL DAY...
UNUSED LANDHONOR MPF-11-2000G PALLET FORKS FRAME (A54757)
UNUSED LANDHONOR...
2017 JOHN DEERE 333G SKID STEER (A53843)
2017 JOHN DEERE...
Kubota RTV500 (A47384)
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
