Recommendation for block heater for John deere 4300 hydro
   / Recommendation for block heater for John deere 4300 hydro #1
ictddt
john deere 4300
Could not get it to start last winter when was well below zero and I needed to move some snow, Promised my self I would install one this summer, Looking for recommendations,
   / Recommendation for block heater for John deere 4300 hydro #2
I bought my 4410 with a block heater from the dealer. I've had to replace it once and bought again from the dealer. Now I would shop around a bit more.
The present 4410 block heater is in a hole in the block behind the starter. You need to remove the starter for access. I've also had good luck with magnetic heaters that you just stick to the oil pan and remove once the engine is running. Another option is to use a heating pad that sticks to the oil pan. That's all that a diesel engine in an older VW uses and they also work quite well. I buy mine on Amazon.
Also a tarp over the hood of the tractor to keep the wind out works wonders for heating a block faster.
great points,
   / Recommendation for block heater for John deere 4300 hydro #4
This is the easiest way to install a engine heater.
Kat's 14875 750 Watt 3 3/4" Lower Radiator Hose Heater buy on amazon​
Price:$18.43
willy
   / Recommendation for block heater for John deere 4300 hydro #5
Tarp and a 1500 watt electric fan heater work well.
The lower rad hose heaters are easy to instal and also work well. That would be my choice.
   / Recommendation for block heater for John deere 4300 hydro #6
Had a Montana that I put two different frost plug in and neither worked properly. Installed glue on oil pan heater and battery warming blanked. Wired them together on one cord with a timer for two hour cycle. That was 10 years ago. Present owner still uses that setup and it never fails to start even at -20. Warm synthetic oil and a warm battery really spins it over.
   / Recommendation for block heater for John deere 4300 hydro #7
My preference is block heaters that mount in a freeze plug in the block. I've installed them in my last 3 tractors without issue, and they work well.
On the rare occasion we get very cold temps, I have also used 500 watts of magnetic heaters on my transmission case.
   / Recommendation for block heater for John deere 4300 hydro #8
The 4300 is equipped with an intake air heater system. See page 22 of Operator's manual.
Activate the system by pushing in on the key switch.
above 0F: hold key in for 10-15 seconds.
0F to -10F: hold key in for 30 seconds.
below -10F: hold key in for 45 seconds.
Start engine. If it runs rough, activate the system by pushing in the key switch until engine runs smoothly.
   / Recommendation for block heater for John deere 4300 hydro #9
That still dosnt mean it's going to start...at least before the battery dies.
   / Recommendation for block heater for John deere 4300 hydro #10
That's true, there's no guarantee it will start. The battery condition is an important factor.
2023 Polaris Ranger SP 4x4 Utility Cart (A55787)
2023 Polaris...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
Craftsman ZTL 7000 Mower 42in mowing deck Parts/Project (A55315)
Craftsman ZTL 7000...
Deere 35G (A53317)
Deere 35G (A53317)
2025 Swict 84in Bucket Skid Steer Attachment (A55851)
2025 Swict 84in...
