Recommend a good Anti-freeze for CK30
   / Recommend a good Anti-freeze for CK30 #1
ulflyer
lexington nc
CK 30H
Mine has never been changed. As usual, my manual is out in shed, but I suspect it will say something like "glycol" which
is not very specific what with many types of AF available. I find it confusing. It has green type but not sure what type that is.
I did try searching with no luck.
   / Recommend a good Anti-freeze for CK30 #2
It doesn't have to be anything special. Just a good premixed coolant/antifreeze will do from any brand name manufacturer, like Peak or similar. There are a TON of different types now for cars and trucks, but your's is a simple tractor, so a good quality basic coolant will suffice. I'm not home so I can't verify, but I believe it's an aluminum head on an iron block, IIRC.
To be absolutely sure you could ask your selling dealer if there is a particular coolant specified for your year/model Kioti.
   / Recommend a good Anti-freeze for CK30 #3
As mentioned, just normal antifreeze. No extended service needed. Also, no wet sleeves so nothing special needed. Either a premix off the shelf or if you have good water, then a 50% mix if buying full strength.
   / Recommend a good Anti-freeze for CK30 #4
Your manual will state regular anti-freeze, just like my tractor does.
   / Recommend a good Anti-freeze for CK30 #5
Maintaining proper Ph will preserve your engine and prevent electrolysis.
   / Recommend a good Anti-freeze for CK30 #6
If you are not buying pre mix, then use distilled water to mix your own.
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
1994 Mack CH613 (A50120)
1994 Mack CH613...
Engel 20' Boat (A50121)
Engel 20' Boat...
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
43013 (A51691)
43013 (A51691)
