Recommend a good Anti-freeze for CK30
   / Recommend a good Anti-freeze for CK30 #1
ulflyer
Bronze Member
lexington nc
CK 30H
Mine has never been changed. As usual, my manual is out in shed, but I suspect it will say something like "glycol" which
is not very specific what with many types of AF available. I find it confusing. It has green type but not sure what type that is.
I did try searching with no luck.
   / Recommend a good Anti-freeze for CK30 #2
It doesn't have to be anything special. Just a good premixed coolant/antifreeze will do from any brand name manufacturer, like Peak or similar. There are a TON of different types now for cars and trucks, but your's is a simple tractor, so a good quality basic coolant will suffice. I'm not home so I can't verify, but I believe it's an aluminum head on an iron block, IIRC.
To be absolutely sure you could ask your selling dealer if there is a particular coolant specified for your year/model Kioti.
   / Recommend a good Anti-freeze for CK30 #3
As mentioned, just normal antifreeze. No extended service needed. Also, no wet sleeves so nothing special needed. Either a premix off the shelf or if you have good water, then a 50% mix if buying full strength.
   / Recommend a good Anti-freeze for CK30 #4
Your manual will state regular anti-freeze, just like my tractor does.
   / Recommend a good Anti-freeze for CK30 #5
Maintaining proper Ph will preserve your engine and prevent electrolysis.
   / Recommend a good Anti-freeze for CK30 #6
If you are not buying pre mix, then use distilled water to mix your own.
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50323)
2017 Big Tex 10ET...
2706 (A51691)
2706 (A51691)
4-27x10.5-15 Hauler Skidloader Tires & Rims (A50774)
4-27x10.5-15...
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
1012 (A51573)
1012 (A51573)
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A52576)
2019 KENWORTH T680...
