Reclaiming Field Perimeters 101
   / Reclaiming Field Perimeters 101 #41
Where I live, poplar is a real problem as a field invader, since suckers pop up from the roots yards away from the main stem...and they can easily grow 2 or 3 feet tall in a season. Old fields tend to get lots of spruces, birches and (sometimes)alders (along with the poplars) around the edges.
We get our share of poplar too. Root suckers and they sprout from seed very well in full sunlight. Fortunately they aren't very tough trees. They snap off if you double them over by hand up to about 1" diameter and what's left standing rots quickly. Looks goofy. :)
   / Reclaiming Field Perimeters 101 #42
blin, I've been in your position. For a couple years before my father passed he could not get on the tractor and our fields and perimeter simply went to heck. I spent the next few summers reclaiming much of it, with the bushhog and carrying a pair of telescoping limb loppers with me on the tractor. As it ride the perimeters about once a summer, I cut all the limbs back, same again the next year and without a great deal of effort, I'm winning the battery (of course, until I don't do it a year!).
Seriously, I always have the limb cutters strapped on the tractor with me.
I have no problem using pole chain saws and loppers if that's the best method to reclaim the field perimeter. I don't mind the hard work, but I don't want this 50 year old plus, tractor newbie, walking into the local farm store and get ribbed for using hand clippers to cut the lower 20 acres.
   / Reclaiming Field Perimeters 101 #44
Besides cutting you can take smaller trees and their roots out with your FEL bucket. A cutting edge really helps with this process.
Push gently on the tree trunk with the bucket level about 3-4 feet above the ground. Once you have a good lean on the tree, you should see the roots on the tractor side of the trunk lifted up a bit above the ground. Gently back up, put the bucket level on the ground and go forward hooking the roots with the cutting edge. Once they start giving, raise the FEL arms and or curl the bucket up a bit to give some lift under the tree. If the tree doesn't come out in one push but looks like it wants to, back up and get another bite on the roots.
If you push on the tree trunk and nothing happens, well that one is chainsaw bait. :laughing: Push with the center of the bucket, work with the tree lean, stay away from dead or weak trees, wear a hardhat, ROPS up.
   / Reclaiming Field Perimeters 101 #45
That's why I shop online!
If you're going to do it yourself, 20 acres isn't enough to justify purchasing anything other than hand tools. For the sake of comparison, spend some time in the Land Clearing forum. Some of those guys have rigs that can reduce 20 acres to sawdust in an afternoon. But those are six-figure rigs and there's no sense in buying one for an afternoon's work, and they're not the kind of thing you can rent. You should think about hiring someone who does it for a living to come in and do the initial cleanup, after that maintaining with your tractor.
I was being a little sarcastic on the hand clippers and 20 acres.
There are a few hunderd acres involved and miles of field perimeter that I need to get under control.
Your thoughts and input all makes sence, even on a large scale, It might be more realalistic to hire someone to get the bulk work done, and then play the role of field maintenance. Another good option to consider.
I will check out the Land Clearing Forum
Thanks for your reply.
   / Reclaiming Field Perimeters 101 #47
I just use a chain saw with the longest blade I can easily handle. Pole saw is nice for small stuff up high but if I'm walking and swinging a 60CC saw with a 30" blade it tends to go thru everything. However my son advocates a Dewalt rechargeable reciprocating saw with a long blade.
Chainsaws dont have blades!!
Only if the I Phone stays in the truck during work! :)
haha
   / Reclaiming Field Perimeters 101 #48
We should start a club :)
   / Reclaiming Field Perimeters 101 #49
My brother in law and I team up to trim our fence lines. I stand in the bed of my RTV 900 with 16" bar chain saw and saw off anything I can reach while he maneuvers the RTV around so I don't have to get up and down. Teamwork like that reduces the time and effort by a factor of at least 10.
A couple of planks laid across the top of the bed gives additional foot of reach. I can get almost all of what needs to be cut to clear the cabs on our tractors from the RTV with a chainsaw. Some higher branches that grow downward require a pole saw to reach up enough to get them out of the way so we usually carry that tool also. We also trim up all the trees around the property that are scattered so we can drive under them. It takes a re-trim every couple of years to get rid of the stragglers.
After cutting limbs and just letting them fall, we either load them on the RTV to haul to a burn pile or if lots of them in a small area, just use the FEL to push them into a pile for burning. We don't have a grapple but that would have been nice to have earlier on when lots of trimming was going on, but now it isn't worth the cost for no more than we have to maintain.
I may look into the electric pole saw idea since we have 3 generators from 1000W to 10,000W capacity. Might be better than cranking on that pole saw which is a bit awkward with that long pole sticking out and you don't want it to touch the ground OR anyone around you.
2016 CHEETAH 40FT CHASSIS TRAILER (A52141)
2016 CHEETAH 40FT...
2011 JOHN DEERE 310SJ BACKHOE (A51242)
2011 JOHN DEERE...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2018 KENWORTH T680...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
PENDING SELLER CONFIRMATIONS (A52141)
PENDING SELLER...
