Receiver for hitch on Box Blade?
   / Receiver for hitch on Box Blade? #1
grwoolf
Austin, TX
I was thinking about welding a receiver hitch on the back of my box blade. I use the box blade for ballast, so it is always on for loader work and it would be nice to have a tow ball on the back. I can't see any big problems with this, does anyone have any thoughts? I will reinforce the back of the box with some 3/8 plate and mount in the center. My box blade is about 500 pounds and I don't expect to put more than about 500 pounds of tonge weight on, just moving a 14' utility trailer around my property. My 3 pt capacity is about 1600 lbs 24" back, so I think this should be OK. This coud affect my ability to back blade, but I can't see this being much of an issue. I also understand the danger of negative tonge weight, I will use chains if there is a chance of this. Any other negatives I am not thinking of (before I make this somewhat permenant)?
   / Receiver for hitch on Box Blade? #2
I think I like the idea of the slip on receiver for the FEL described in a recent post. Quick to take on and off and a lot easier to move a trailer with something on the front.
I liked the front mount also. That may be a future project, but I'm not sure how to make it fit tightly and make it work with and without the toothbar installed. Plus, I can leave the rear mount on at all time, and the FEL can't really be used with the receiver installed in the bucket. Actually, I guess it could, but I wouldn't.
   / Receiver for hitch on Box Blade? #4
I bolted one on mine, made an L bracket out of 1/2 X 4 and bolted it to the back.
   / Receiver for hitch on Box Blade? #5
</font><font color="blue" class="small">( I liked the front mount also. That may be a future project, but I'm not sure how to make it fit tightly and make it work with and without the toothbar installed. )</font>
You obvioulsy have not requested a copy of my plans. See the post below for details on how to get your own set of plans.
Clamp-on bucket receiver
   / Receiver for hitch on Box Blade? #6
I bolted the trailer hitch ball on the top center of my FEL, bucket hooks on the outside of FEL and hitch ball in center. Works like a champ for me but I don't try to climb mountains or extremely heavy loads but so far it has worked great and makes moving trailers around real easy having it in front.
I have a 5x8 5,000 pd rated hydraulic dump trailer which my little BX23 moves around fine this way.
   / Receiver for hitch on Box Blade? #7
Hey Kel,
how's the driveway coming along?
   / Receiver for hitch on Box Blade? #8
You can buy the 2 inch reciever tube at TSC. Just weld it on the top middle of the box blade and slide in a hitch when you need one.
Ben
This is done. I got the receiver at TSC ($15), a little steep, but not too bad. I welded it onto a peice of 1/2" plate and then welded the plate onto the back of the BB. I also welded a catch hook on the top of the receiver. It works great, very easy to move a trailer without ever getting out of the seat.
   / Receiver for hitch on Box Blade? #10
gr; What, no photo? I beleive there is a law somewhere on the books in Podunk, Alabama, that states, and I quote, " All projects shall be accompanied by relevant photographs, under penalty of law." The post police are on your spore mister. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
John Deere 335 Round Baler (4ftx4ft) (A52748)
John Deere 335...
1985 Corn Husker Hopper Trailer (A50514)
1985 Corn Husker...
2017 Freightliner M2 106 24FT Box Truck (A50323)
2017 Freightliner...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
John Deere 2700 Mulch Ripper (A50514)
John Deere 2700...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2015 FREIGHTLINER...
