Rec Trailer for 40-50 hp
   / Rec Trailer for 40-50 hp #1
SCDolphin
Columbia, SC
Kubota L5240: Craftsman GT6500
I am looking at either a Kubota 5030 or JD 4000 series.
What would be the shortest trailer length and width for tractor with fell and bush hog
Thanks
   / Rec Trailer for 40-50 hp #2
Not sure about the shortest possible that you could get by with.
I would think a 20 footer would be fine though.
   / Rec Trailer for 40-50 hp #3
We have a 3830, which is probably a little shorter than the 5030, and with the bucket on and a 6' rotary cutter, the rear wheel hangs over the end of our 20' trailer. I'd say 20' was a minimum length. I wouldn't mind a couple extra feet.
   / Rec Trailer for 40-50 hp #4
Of course, it's not just the length you'll need to worry about. You'll need one that can support the weight of those tractors.
You'll need to deduct the weight of the trailer from the overall capacity, then figure out how much the tractor and all implements will weigh and buy axles that have enough capacity for all of it.
Then you'll have to make sure that the tow vehicle can also take all the weight, especially being sure the tongue weight will be correct.
I agree that 20' would be a minimum, 24 would be almost ideal, but then that changes a lot. Rules on overall length can make you have to have a different driver license.
Many variables come into play.
John
   / Rec Trailer for 40-50 hp #5
Do not buy by size alone. I recently looked at a bunch of 16' landscape trailers. On the surface, they appeared to be all the same. However, some were rated for only 2990# total weight (trailer and load) and others were rated for 7000# You will need the 7000# size or larger. One other thing, make sure there is a sticker with the gross rating and the mfgr name on the frame. Do not rely on what the salesman tells you. A 16' trailer weighs about 1400-1500#. That gets deducted from the total rating to determine your allowable load. A 20' trailer will weigh even more. Read the recent posts about chains and binders; they are very helpful.
   / Rec Trailer for 40-50 hp #6
I would recommend dual 5200lbs axles with brakes on both axles.
   / Rec Trailer for 40-50 hp #7
I have a 4500 mahindra very heavy machine bought a 20 ft lowboy gooseneck duel 6000lb axle electric brakes. 4500 mahindra 6ft brushog,disc ,boxblade
   / Rec Trailer for 40-50 hp #8
My 4720 w/ FEL and a MX6 fills my 22 ft trailer and the tail wheel hangs off by 8 inches.
2024 Case International 45C Tractor (RIDE AND DRIVE) (LIKE NEW) (A50774)
2024 Case...
2015 Caterpillar 299D2 High Flow Compact Track Loader Skid Steer (A51691)
2015 Caterpillar...
Moyno Sludge Pump (A50121)
Moyno Sludge Pump...
1980 AM General M35A 2.5 Ton 6x6 Cargo Truck (A50323)
1980 AM General...
Case-IH Engine (A50121)
Case-IH Engine...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A50322)
2014 JLG G12-55A...
