strum456
Platinum Member
I just finished rebuilding the lift cover on my 860. Before the rebuild, it didn't lift high enough and it leaked down pretty bad. I replaced the cylinder o-rings and the cam follower pin. I also replaced all the o-rings that go between the cylinder and the lift cover, etc..
When I first started the tractor, I had no hydraulic lift. No surprise...air I figured. I cracked the bleeder on the pump and it started to work, but really slow and jerky. I proceed to work the lift arms up and down and mess with the bleeder for about 15 minutes, but it still lifts slow. On the plus side, the lift arms go much higher now.
Here are my thoughts.
1. I STILL don't have all the air out???
2. An o-ring did not seal. How on earth would I find out which one?
3. I didn't adjust the linkage properly. I followed the directions in the book, and after a couple hours of messing around, I determined that it would not be possible to get both measurements correct at the same time. Could incorrect adjustment cause slow lifting? I thought it would only affect the range of motion and draft control (which I never use anyway).
