rebuilding offset disc
/ rebuilding offset disc #1
troweller
Bronze Member
Kubota 3010, Farmall Cub
I am trying to rebuild a old 4 foot offset drag disc with hydraulic lift wheels.
I got the end nut off the axle and one disc off. Do i just knock the axle with
a block of wood and a sledge?
/ rebuilding offset disc #2
You need to unload the weight off the axle by placing the whole disk frame on jack stands if you want to remove the axle that way.
You can also unbolt the bearings from the hangers ( frame still supported by jack stands) and just roll the whole assembly out from under the frame and roll it up on end then pull everything off like a shiskabob.
2016 CATERPILLAR 416F2 BACKHOE (A62129)
2016 CATERPILLAR...
Wooden Wagon Wheel Chair (A64127)
Wooden Wagon Wheel...
40ft Shipping Container (A64194)
40ft Shipping...
2006 Deere 160CLC (A64126)
2006 Deere 160CLC...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
2010 GREAT DANE SUP-1114-31053 T/A REFRIGERATED TRAILER (A59914)
2010 GREAT DANE...
