Rear Finish Mower Rebuilding my 72” King Kutter Finish Mower
   / Rebuilding my 72” King Kutter Finish Mower
591-585. Blades have three holes. My blades mount using two bolts to the spindle.
Had a hard time with caster wheel spindles bending and wear. Scut 4x4 in rough terrain and lots of back and forth maneuvering. Changed to 3500# axle bearings, spindles and hubs. At the the time 1/3 of cost of OEM parts. Did require some fabrication and welding. Been trouble free ever since.
I’ll look into getting a set and will post part numbers here when I order them.
Today was a very wet day power washing the deck and larger parts
- 1st reason was degreasing/deep cleaning to save some work later.
- 2nd reason was to rinse off the rust converter when I was done using it which also etches bare metal to prep for paint
Tomorrow I will fabricate the belt cover hold downs and cap the rusty rectangle stock ends to slow the internal corrosion.
I may or may not get to sanding and priming
   / Rebuilding my 72” King Kutter Finish Mower #13
I hate to tell you this but you are working far to hard to clean up and paint your mower. I had some Hutterite friends sand blast and paint my mower for me. $160 and they used some left over paint they had laying around. I didn't get the underneath painted but I like the color and the mower looks great. They saved me hours of work for what I think was a very reasonable price.
Other than hard parts I’m only into this for like $60. Most of the paint/primer I had on hand.
Also I learned recently in both Tennessee or Alabama that anything you want done right or even just simply done at all, you have to do it yourself.
   / Rebuilding my 72” King Kutter Finish Mower #15
Well I concider myself very fortunate that they cleaned up and painted the mower for me. I had it laying in pieces for about 5 years and never got around to painting it and putting it back together. I'm using the mower now and if I wouldn't have hired them it would still be laying around.
I agree with you on doing things yourself.
I wish I had someone with a blaster that could help me.
It is on my list of tools to buy
   / Rebuilding my 72” King Kutter Finish Mower #17
Got the belt hold downs and priming done.
Tomorrow I’ll do some light sanding if needed to make a good surface for the paint.
After that I’ll be prepping/painting things like the gearbox and wheels etc.
   / Rebuilding my 72” King Kutter Finish Mower #19
Better paint job than King Kutter already..
Discovered some cracks near where I capped the the rectangle tubing.
I welded the cracks up and painted the gearbox today
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56435)
2002 Chevrolet...
3 HOLE FRIGIDAIRE FOOD WARMER (A58374)
3 HOLE FRIGIDAIRE...
78in Dual Cylinder Brush Grapple Skid Steer Attachment (A56857)
78in Dual Cylinder...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
2019 PETERBILT 579 (A58214)
2019 PETERBILT 579...
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
