Rebuilding Mitsubishi k3d sleeve question
   / Rebuilding Mitsubishi k3d sleeve question #1
markct
Platinum Member
northfield connecticut
gradall g3r excavator, kawasaki mule 2500,ford 8000,and a 1936 caterpillar road grader
So my tractor I bought non running appears to need a rebuild. The previous owner said it kept getting harder and harder to start then wouldn't. He had removed the injection pump, I got it rebuilt and also noticed a hole in the air cleaner hose and to my fear it appears the engine got dusted and doesn't have enough compression to fire even on ether. So anyhow a rebuild it is. I see most kits say semi finished sleeves and they need to be finish bored, can I buy ones already finished somewhere? Otherwise I may just hone mine and re ring it
   / Rebuilding Mitsubishi k3d sleeve question #2
I usually try to do the cheapest route first which would be garage honing and rings in your case but if the engine was essentially ran without an air cleaner it is likely you won't get away with that. You'll need to check piston clearance and I wouldn't even attempt a re-ring if it's greater than 0.010". Some people will say less but I had an engine that was running with 0.020", albeit barely by re-ringing. Ultimately it had to be over-bored shortly after the attempt. If you're going to re-sleeve you'll probably want to do a final shop bore and hone on them after installation to make sure the sleeves have the correct finish and roundness required in the end. Sleeves can distort upon installation and you'll want to be sure this distortion is removed before installing new pistons. So my general rule is if you can get by fairly cheap go ahead and do so otherwise once you start down the road of boring, etc. you might as well do everything by the book to keep things matched as well as possible (i.e. no use putting new pistons in old bores, etc.) Obviously you'll have to open up your wallet accordingly and it makes sense to go all the way at that point as you can expect another 30-40 years out of it with the same usage. I'm a little torn at this point with what I've seen regarding bearings. Usually I would replace them along the way but I've seen almost no wear every time I took them apart and would chance reusing them during a cylinder refurbishment at this point.
   / Rebuilding Mitsubishi k3d sleeve question #3
According to the factory engine repair manual all the K3 blocks were not a sleeve style engine, direct bore in block. However just like any other they can be sleeved. Maybe you are looking at repair sleeve kits? I see three oversize pistons .25mm, .50mm, .75mm, which require block boring/honing in the usual fashion.
I'm not seeing a specific piston to bore clearance but the service limit is .012" for all.
Thank you, I guess I misunderstood that when I saw sleeves in the kits offered on eBay, what is your source for oversized pistons I haven't seen anywhere list them
   / Rebuilding Mitsubishi k3d sleeve question #5
NCW Tractor Parts, LLC can get most parts and seem to be pretty sharp on Mitsubishi engines in particular. If not listed on their website give them a call.
Well I finally got the engine opened up, good news is the bores cleaned up nicely with some honing, minimal taper measured, unfortunately the thing was bored .25 mm over at one time, and I will be darned if I can find a ring set that size. Everyone has standard, and .020 thousandth in oversized, but can't find .25mm, which is almost the same as .010 inch oversized. I have a set of standard rings already that came with a gasket kit almost tempted to use those despite end gap being somewhat oversized that way. Frustrating little engines, even the link Kernopelli shared only shows standard size rings.
   / Rebuilding Mitsubishi k3d sleeve question #7
JEGS, Summit and several other of the speed shops sell a ring grinder, inexpensive it is a flat fine grinding wheel turned by a crank, get your 20 overs and file to perfect fit.
I thought about that, but realized after I was mistaken and the .020 over were for a k3e I don't seem to be able to find anything oversized for k3d, even thru CaseIH parts lookup, the 244 tractor used the k3d, they are no longer shown as available unfortunately
   / Rebuilding Mitsubishi k3d sleeve question #9
Give NCW a call, they can get many parts that arent listed on their website. I will bet they can get you set up with the right rings.
Case Parts | Buy Online & Save lists the .25mm O/S rings for the 244......."RING SET, piston 0.25 mm O/S 1271932C1 $72.57"
I emailed NCW, CaseIH doesn't show them in stock says they are discontinued, but maybe a dealer could hunt some down somewhere if I have to
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
2002 Wacker RD11A Tandem Smooth Drum Roller (A54811)
2002 Wacker RD11A...
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
Frontier WR1008 - 8 Wheel Pull Type Hay Rake (A55218)
Frontier WR1008 -...
2015 Mitsubishi Outlander Sport SUV (A53424)
2015 Mitsubishi...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
