Rebuilding Branson 4720h Kukje A2300. What I have learned so far.
   / Rebuilding Branson 4720h Kukje A2300. What I have learned so far. #11
overall do you believe the issues are from abuse or from design? i have a similar vintage 4720h with 725 hours on it currently. it smokes on startup for maybe 10 seconds.
I think it was poorly taken care of and people use starting fluid to start it. What kind of smoke does it have on startup? White blue or black?
   / Rebuilding Branson 4720h Kukje A2300. What I have learned so far. #13
mostly black smoke.
   / Rebuilding Branson 4720h Kukje A2300. What I have learned so far. #14
My 8050 has always given off a puff of black smoke on a cold start.
So I received the cylinder head and pistons from China. They are absolutely identical to what was in the tractor. Even the casting numbers. So for those that are interested the 1700 200p and 2300 are Cummins engines. All of the parts interchange. There's no need to purchase the parts from Branson. They might even be made in China and just sealed in a Branson package. We will see once I get the tractor started but bearings gaskets etc are spot on and high quality
   / Rebuilding Branson 4720h Kukje A2300. What I have learned so far. #17
Thanks for your information Bob. I just bought a 2007 4720 and am wondering how much I will need to do.
My engine smokes, (blue), a lot for a few minutes after startup then just a bit after that. I'm following your progress with much interest.
The previous owner of mine really neglected everything.
   / Rebuilding Branson 4720h Kukje A2300. What I have learned so far. #18
You probably have a small oil leak from the valve guides. How many hours on the engine? A good machine shop could probably do the head for reasonable money. PO probably overheated the engine would be my guess.
   / Rebuilding Branson 4720h Kukje A2300. What I have learned so far. #19
Thanks for your reply #15.
I'll start a new thread about mine.
I don't want to hijack Bob's.
   / Rebuilding Branson 4720h Kukje A2300. What I have learned so far. #20
I hate it when someone starts a thread laden with specific details but then fails to provide followups or a conclusion. Was a re-build actually performed and was it successful?
1998 National RV Tropi-Cal T/A 35FT Class A Motorhome (A55853)
1998 National RV...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2011 Ford F450 Diesel with Just 156638 Miles (A55302)
2011 Ford F450...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A55852)
2014 Peterbilt 384...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A55302)
2008 Ford F-250...
