Rebuild shuttle for 580d loader
/ Rebuild shuttle for 580d loader #1
Wattledo
Rockhampton,Queensland,australia
Case 580D loader
I have replaced the forward clutch plates,full seals, pump and torque converter on the 580Dloader and unable to get either forward or reverse movement. Have checked the pressures as per the trouble shooting advice in the manual and they are within the required tolerances. Am at a loss as to where to from here. Can anybody suggest a solution.
/ Rebuild shuttle for 580d loader #2
G'day mate and :welcome: have you checked the driveshaft into the diff/g/box is turning when you put the shuttle into gear just wondering if it is a prob further back.
Jon
Yes mate, have checked the drive shaft and it's doesn't move. This is the second time I have rebuilt the shuttle and replaced the forward clutch plates. Have rechecked all seals aren't damaged but still no drive in either forward or reverse.
/ Rebuild shuttle for 580d loader #4
Have you checked the elec side of the trans dump you may be powering up the solenoid. They are a fairly straight forward system not alot to go wrong with what you have done.
Jon
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
Kobalt Ceramic Tile Saw (A62613)
Kobalt Ceramic...
2013 Land Rover Range Rover AWD SUV (A64557)
2013 Land Rover...
2008 Chevrolet Silverado 2500 Crew Cab (A62613)
2008 Chevrolet...
