Rebuild of International harvester 384
   / Rebuild of International harvester 384 #1
summoner1961
Pipe creek, Texas
international case 384
Hello all! Looking for some advice... I'm no where close to putting it together yet, but trying to think ahead.
When I'm finally done cleaning, replacing, putting it all back together (parts running up to 2500.00$) When I first try to start it, anyway to prime the oil pump? I will be using a rebuilding oil to coat everything as it goes together. My worry is time, when I am finally able to turn the key, will that rebuilding oil be enough?
I have rebuilt a gasoline motor, and that was no problem, pull the distributor and use a drill to turn the oil pump. On this 384, the camshaft is geared on the oil pump, so the drill idea will not work...
How can I prime the oil pump and system????
   / Rebuild of International harvester 384 #2
I would disable the ignition system, if gasoline, and or fuel system if diesel and use the starter to roll the engine until you see oil pressure. The oil you used assembling the engine will protect moving parts until the pressure comes up; take care not to overheat the starter
2016 John Deere 318G Skid Steer Loader (A51573)
2016 John Deere...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
378484 (A51572)
378484 (A51572)
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
New/Unused Agrotk Tire Changer (A51573)
New/Unused Agrotk...
2011 Chevrolet Camaro Convertible Coupe (A52377)
2011 Chevrolet...
