Rebuild of International harvester 384
   / Rebuild of International harvester 384 #1
summoner1961
Pipe creek, Texas
international case 384
Hello all! Looking for some advice... I'm no where close to putting it together yet, but trying to think ahead.
When I'm finally done cleaning, replacing, putting it all back together (parts running up to 2500.00$) When I first try to start it, anyway to prime the oil pump? I will be using a rebuilding oil to coat everything as it goes together. My worry is time, when I am finally able to turn the key, will that rebuilding oil be enough?
I have rebuilt a gasoline motor, and that was no problem, pull the distributor and use a drill to turn the oil pump. On this 384, the camshaft is geared on the oil pump, so the drill idea will not work...
How can I prime the oil pump and system????
   / Rebuild of International harvester 384 #2
I would disable the ignition system, if gasoline, and or fuel system if diesel and use the starter to roll the engine until you see oil pressure. The oil you used assembling the engine will protect moving parts until the pressure comes up; take care not to overheat the starter
Husqvarna 120 Chainsaw (A51573)
Husqvarna 120...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
50ft Fuel Line (A51573)
50ft Fuel Line...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2022 John Deere 8RX 410 Tractor (A53342)
2022 John Deere...
