Rebuild both cylinders at the same time?
   / Rebuild both cylinders at the same time? #1
AKfish
Super Member
Alaska
JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
While in the tractor shed the other day, I noticed that the right side boom cylinder on the 110 loader has got a pretty good leak started. Nice puddle there on the ground! Looked up the seal kit repair on www.JDParts.com and it's about ~$42.00. Whew... :)
So, my instinct is to rebuild both loader cylinders at the same time. I'm doing the work and it's a pretty cheap repair. But, the left side is dry - no problems. (If it ain't broke... don't fix it?!?) Nonetheless, my logic is that after rebuilding the right side the loader might have slightly unequal lifting capabilities and the older cylinder (~1,200-1,300hrs) will start to fail in short order.
Any thoughts or opinions?
Thanks.
AKfish
   / Rebuild both cylinders at the same time? #2
I would rebuild both. They each have the same wear, only one failed first.
   / Rebuild both cylinders at the same time? #3
It is a crapshoot. Nothing says the other one will or will not start leaking any tiime within the next 1000 hours of use. Do whatever makes you happy.
   / Rebuild both cylinders at the same time? #4
I would also rebuild both
   / Rebuild both cylinders at the same time? #5
Buy two kits and put one in...
   / Rebuild both cylinders at the same time? #6
I agree, UNLESS you cant have unexpected downtime from a leaking cylinder. The other one could die tomorrow, or it could be fine for 10 more years.
Aaron Z
   / Rebuild both cylinders at the same time? #7
I am in the "do both" camp, like headlights, wipers, brakes, tires, ect they both have the same wear on them. Only time I wouldn't is if there is obvious damage from an outside force on the side that's leaking.
   / Rebuild both cylinders at the same time? #8
Why is it that in my mind I would've done only one, until Kenny showed up? :confused: :thumbsup:
   / Rebuild both cylinders at the same time? #9
Rick
I agree with you. There's no telling how many hrs use the other cylinder will give before it fails. I'm in the "if it aint broke don't fix it" group.
   / Rebuild both cylinders at the same time? #10
Fix the one that leaks . I've seen this repairs go both ways . It is either fixed or leaks worse . The other cyl . may never leak , unless you open it up .
2017 Chevrolet Colorado Crew Cab Pickup Truck (A53422)
2017 Chevrolet...
2016 CATERPILLAR 313FL EXCAVATOR (A52705)
2016 CATERPILLAR...
JOHN DEERE 3020 TRACTOR (A54756)
JOHN DEERE 3020...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
1999 TRAILMOBILE DRYVAN (A53843)
1999 TRAILMOBILE...
Carnival Ticket Booth (A51691)
Carnival Ticket...
