Backhoe Reasonable to expect to move BH between tractors?
   / Reasonable to expect to move BH between tractors? #1
canoetrpr
Ontario, Canada
Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
How reasonable is it to expect that I will be able to move a backhoe I buy now for my Kubota L3400 to a future tractor (e.g. Grand L3540) which will definitely require a different sub-frame?
I've pondered buying a backhoe but then think that I will lose money if I sell my tractor with the backhoe on it, or, I will be out $1k or so buying a new sub-frame to move it on to a different tractor.
I'm not in a position to trade up now but might be in 5 years or so. I figure a loss of $1k or so isn't too bad to be able to use a backhoe now that I can transfer to a future tractor.
What do you think?
BTW. It is not a huge issue for me to buy a bigger backhoe for a future GL or similar tractor given the tasks I am going to use it for... nothing other than hobby uses - planting a tree, digging flower beds, etc. etc. I figure a 8ft backhoe should be plenty.
The BH I had in mind was the Woods BH80X.
   / Reasonable to expect to move BH between tractors? #2
I'd say it would be a good idea.................... as long as Woods makes a subframe kit for the new tractor. Yes, you'd lose what you spent on your current subframe, but in the grand scheme of things it wouldn't be so bad. Aside from the subframe, you'd most likely need a new hydraulic hose kit, but not a big deal.
   / Reasonable to expect to move BH between tractors? #3
You can also sell your sub-frame on ebay, every now and then they are listed and do sell. I have a watch for a woods sub-frame there now ... KennyV
   / Reasonable to expect to move BH between tractors? #4
It should be trivial to get a new subframe for a popular Kubota model. Woods probably has them in stock and develops new subframes for new Kubotas all the time.
   / Reasonable to expect to move BH between tractors? #5
3400 to 3540 may even be the same subframe. Or they may share components. Will have to ask Woods. May be cheaper than you think.
jb
   / Reasonable to expect to move BH between tractors? #6
The BH80-X backhoe I purchased for my L3540 HSTC needed specific subframe kit(5" longer for cab tractor) about $600.. well worth it . I'll try to post pics.. and my fork attach I made...
rokee101:
That is a really NICE looking setup. Some day I hope to have a tractor with a cab as well and if it fits that well, I think that I might as well save up and get that BH80X sooner rather than later.
2014 Jacobsen AR3 Commercial Mower (A53421)
2014 Jacobsen AR3...
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
2004 Towable Light Tower (A55851)
2004 Towable Light...
ALLISON TRANSMISSION (A55745)
ALLISON...
2000 Sterling L9513 Winch Truck (A55315)
2000 Sterling...
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
