Rear working light location on B2920?
   / Rear working light location on B2920? #1
gabrichter
Bronze Member
South Dakota
2012 Kubota B2920
OK have my new B29020 and kept the 55w flood off old tractor to put on this one. Is there wires in rear that run off light switch that I can just plug into and where are they located?
   / Rear working light location on B2920? #2
The wires are located under the right rear fender -- look for two bullet connectors taped to the harness with blue tape. The lead is powered when the engine is running, so you will need to install a switch.
Be sure the old light doesn't draw too much current since the 2920 only has a 20A alternator, and only about 14-15A are available to charge the battery and run accessories.
I checked and a standard 55w halogen pulls about 4.5 amps. Will that work with the existing lights?
   / Rear working light location on B2920? #4
Should be fine. I have two mounted on my 2920 ROPS.
   / Rear working light location on B2920? #5
You should be okay. The stock dynamo puts out around 14.5 charging amps, and I believe I calculated the tractor lighting to draw somewhere around 5.3 amps give or take. You should come in just under 10 amps or so for total draw.
2014 UTILITY 53X102 DRY VAN TRAILER (A43004)
2014 UTILITY...
John Deere Z960M (A44502)
John Deere Z960M...
2020 Chevrolet Tahoe SUV (A42744)
2020 Chevrolet...
2015 FORD F-550 SUPER DUTY (A45333)
2015 FORD F-550...
2008 Ford F-150 4x4 Extended Cab Pickup Truck (A42744)
2008 Ford F-150...
2022 JOHN DEERE 210G LC EXCAVATOR (A45046)
2022 JOHN DEERE...
