Rear Wiper install
   / Rear Wiper install #21
When are you taking the plastic off the seat:)
Why would I take it off ? I JUST REPLACED IT
   / Rear Wiper install #23
New seat?
Seat sensor shorted out..factory rep sent me a complete seat replacement no charge. .but this doesn't have a thing to do with wriper install.
   / Rear Wiper install #25
I know I saw the picture with the plastic on the seat on thought maybe it reminded you of sitting on grandma's couch with the plastic cover on it:D
Notice after install that it was time to replace the two year old wiper blade found two replacement blade Trico 14-1 or a better TRICO Onyx*Beam Wiper Blade, 14" available at my local auto supply...when buying a blade this short be sure it's a front blade standard J hook...
Just replaced front wiper blade after two year ..it from day one squeaked and chattered...New Trico Onyx*Beam is very smooth running ....rear wiper making noise (chattering) on first use ..picking up a replacement blade for new rear wiper ...the blades that come with the kit are junk don't know if that are just old from long term storage or just cheap or both...for $176. At least they should send a a good blade just sayng.
   / Rear Wiper install #28
Trying to find harness in roof. Didn't take totally down. Should harness be in roof by front set of switches or side switches?
   / Rear Wiper install #29
Take the 4 bolts that hold the roof off. Lift the roof up and prop it with a 2x4. You will see towards the back that everything is there and is zip tied to the tractor.
   / Rear Wiper install #30
Probably just Chinese rubber. Even the good blades only last a year down here in the heat. When I have the annual inspection done on the truck, I have them put new wiper blades on. Then I'm good for another year. :rolleyes:
MAHINDRA 3650P TRACTOR (A60430)
MAHINDRA 3650P...
2021 CATERPILLAR 299D3 XE SKID STEER (A60429)
2021 CATERPILLAR...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
CASE IH MAXXUM 115 TRACTOR (A60430)
CASE IH MAXXUM 115...
Case-IH 370 Steiger (A57148)
Case-IH 370...
2014 LOAD KING BELLY DUMP TRAILER (A58214)
2014 LOAD KING...
