Ballast Rear wheel weights
/ Rear wheel weights #1
punkinspecial
I am considering rear weights for my dk55. Are they available from Kioti dealers or are there any weights from other manufacturers that may fit?
/ Rear wheel weights #2
I'm not sure, but if you have industrial tires, the wheel weights from Kioti won't work. I believe they are only for R1 wheels.
Check the website under accessories for the weights.
www.kiotitractor.com
John
I should have added that my dk55 has AG tires. I forgot about the industrial option. A case of oldageitis!
/ Rear wheel weights #4
Why not just load your tires? They have started using something new here in WA, beet juice! won't rust or corrode your wheels is environmentally friendly won't freeze down to a certain temp don't remember what that is, weighs about eight pounds to the gallon.
I also should have added that the tires are loaded. I just want a little extra weight on the rear. It is not always easy to attach a counter weight on the 3 point hitch. Some of my land is rough and hilly, amd sometimes I use it in tight places. Thanks
/ Rear wheel weights #6
It appears that the new website for Kioti doesn't have the wheel weights listed, nor are they listed under the tractor's specs.
I'm fairly sure that I saw them offered under the old website, so check with a Kioti dealer.
I'd be careful about adding wheel weights to loaded tires. I know many people do, but make sure you find out the MFG recommendation on ballast maximums.
John
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
2716SFL (A61567)
2716SFL (A61567)
82" X 18' EQUIPMENT TRAILER (A64277)
82" X 18'...
2002 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2002 Ford F-250...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2022 EZ-GO ELITE...
