Rear wheel lug bolts
/ Rear wheel lug bolts #2
Only ones I've dealt with where pressed in, I was able to get most out , but ended up taking the hub to a mechanic shop that was able to use a press to remove the bent one. They also pressed the new ones in for me.
/ Rear wheel lug bolts #3
do you have the hub off the tractor onthe bench, or will you be doing it on tractor?
and do you have a hole saw? :)
/ Rear wheel lug bolts #4
There are a lot of different styles of hubs, a pic would make it easier to tell what you have.
NAPA is a good source, most stores can have the studs in a short time if not in stock.
/ Rear wheel lug bolts #5
650 only has 1 style of hub...
/ Rear wheel lug bolts #8
i hope not...
